[GRASS-user] wxGUI: new column doesn't appear in properties
Paolo Craveri
pcraveri at gmail.com
Tue Apr 21 05:53:41 EDT 2009
Hi to all
in wxGui (grass6.5.svn):
1)load a vector map in Layer manager;
2)show attribute table -> manage tables -> add a new column and close
the window;
3)in layer manager, select the vector map, properties->labels->name of
column to be displayed: the new column isn't in drop-down list.
The same also in the case you insert some values in the new field.
Are there any ways to refresh the list of fields without remove the
vector map from layer manager and reload it?
Paolo C.
Lat. 44° 39' 11.08'' N Long. 7° 23' 25.26'' E
