[GRASS-user] wxGUI: new column doesn't appear in properties
Martin Landa landa.martin at gmail.com
Tue Apr 21 06:08:15 EDT 2009
2009/4/21 Paolo Craveri <pcraveri at gmail.com>:
> 1)load a vector map in  Layer manager;
> 2)show attribute table -> manage tables -> add a new column and close
> the window;
> 3)in layer manager, select the vector map, properties->labels->name of
> column to be displayed: the new column  isn't in drop-down list.
> The same  also in the case you insert some values in the new field.
> Are there any ways to refresh the list of fields without  remove the
> vector map from layer manager and reload it?
Fixed in r36835.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
