[GRASS-user] ' v.in.db ' question
Markus Metz markus.metz.giswork at googlemail.com
Wed Apr 22 04:18:07 EDT 2009
Bulent Arikan wrote:
> The file is on my Desktop!
which is usually
/home/<username>/Desktop/
on Linux
and usually
C\:Documents and Settings\<username>\Desktop\
on Windows
Neither of these is the same like $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/,
you must set database=<Desktop folder>, otherwise v.in.db can't find the
table.
>>> Hi,
>>> I am trying to import an OpenOffice dbf into a wgs84 PERMANENT
>>> Location. I did this several times in the past with older versions
>>> of GRASS. I enter all the necessary information (input table, column
>>> names for x, y, z and CAT#). The Connection tab shows "dbf" for the
>>> driver name and database name reads "
>>> $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ "
>>> I get this message:
>>> DBMI-DBF driver error:
>>> Table 'Iron_II_KNOWN_Sites' doesn't exist
>> Stupid question: is Iron_II_KNOWN_Sites.dbf in "
>> $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ " or in a different folder?
