[GRASS-user] Re: v.lidar.growing dbmi: Protocol error
Jack Lonsdale lonsdale at unbc.ca
Wed Apr 22 17:09:24 EDT 2009
If this helps:
Tried this on Ubuntu 8.10 using both GRASS 6.3 and 6.4 svn
On Wed, 2009-04-22 at 13:58 -0700, Jack Lonsdale wrote:
> I am continuing to try and use Grass to process my LiDAR data. However,
> having completed v.lidar.edgedetect successfully I am unable to complete
> v.lidar.growing
> firstly, just to check, the 'first' parameter is the raw dataset? If not
> how do I create the first return dataset?
> Secondly, if I run the following:
> v.lidar.growing input=alrf_subs_edge at lonsdale output=alrf_subs_grow
> first=alrf_subs_raw tj=0.2 td=0.6
> All I get is a dbmi:Protocol error, It was impossible to open this
> table!
> I have seen someone else had this problem on the list in the past but no
> definitive solution seemed to occur.
> Thanks,
> Jack
