[GRASS-user] Grass 6.4 & python.
Milton Cezar Ribeiro miltinho.astronauta at gmail.com
Wed Apr 29 17:31:10 EDT 2009
Hi Colin
I will give a look on all these tips.
Thanks a lot.
milton
2009/4/29 Colin Nielsen <colin.nielsen at gmail.com>
> Hi Milton,
> This is a common error I have come across, and shouldn't be a problem
> with your Python installation. It is just a question of getting
> PYTHONPATH and possibly PYTHONHOME (Which needs to be in a windows
> path format) into the right format.
> For example, the following has been added to the native wingrass
> installer's version of the "grass64" startup script. Make sure to
> adjust the paths to your computer's locations.
> # Set the PYTHONPATH variable
> PYTHONPATH="$GISBASE/etc/python:$GISBASE/Python25:$PYTHONPATH"
> export PYTHONPATH
> PYTHONHOME="C:\GRASS-6-SVN\Python25"
> export PYTHONHOME
> Also, check http://trac.osgeo.org/grass/wiki/CompileOnWindows#Usage
> for details on how to get Python running under msys on windows.
> Note: even with these adjustments, wxpython still can't display maps
> on grass-6.5.svn or grass-7.0.svn
> -Colin
> On Wed, Apr 29, 2009 at 11:44 AM, Milton Cezar Ribeiro
> <miltinho.astronauta at gmail.com> wrote:
> > oops again:
> > " But if I go to a DOS windows (using cmd)"
> > 2009/4/29 Milton Cezar Ribeiro <miltinho.astronauta at gmail.com>
> >> Hi Glym,
> >> But if you go to a DOS windows (using cmd)
> >> type python (it starts python 2.6)
> >> and try import sys, it works fine on text/DOS mode?
> >> By the way, the pythopath was included as windows environment variable.
> >> Any suggestion?
> >> miltinho
> >> 2009/4/29 Glynn Clements <glynn at gclements.plus.com>
> >>> Milton Cezar Ribeiro wrote:
> >>> > Thanks for the reply. I have tryed on two ways, both not work for me
> >>> > (under
> >>> > windows vista).
> >>> > 'import site' failed; use -v for traceback Traceback (most recent
> call
> >>> > last):
> >>> >   File "c:/OSGeo4W/apps/grass/grass-6.5.svn/etc/wxpython/gis_set.py",
> >>> > line
> >>> > 23, in <module>
> >>> >     import os
> >>> > ImportError: No module named os
> >>> This indicates that your Python installation is borked; it can't find
> >>> its standard library modules.
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090429/506921a6/attachment.html
