[GRASS-user] Georectification
ifj. Stefán István
istefan at stef.hu
Thu Apr 30 01:22:12 EDT 2009
Hi!
Try "map" instead of "map at PERMANENT" in command i.target.
I've also experienced this problem.
If I didn't specify the mapset informations in the map names, it works. So try
write just "state" instead of "state at PERMANENT" and "map" instead
of "map at PETMANENT" everywhere.
This helps for me, though I use the gui for i.group and i.target.
Regards,
Istvan
csütörtök 30 április 2009 dátummal Joe Bayles ezt írta:
> I'm not even really there yet. I've followed the following steps:
> Created an undefined XY location for importing
> Created a defined UTM location for georeferencing
> r.in.gdal (don't have the exact line written down, but it worked, I have
> displayed the TIFF as a raster)
> i.group group=map input=state at PERMANENT (assigned the one image to a group)
> i.target group=map at PERMANENT location=georeference mapset=permanent
> (targeted the UTM location)
> d.mon start=x0 (started the monitor)
> Here's where it gets... not good.
> i.points group=map at PERMANENT (attempt to start identifying points)
> and I get this:
> Target information for group [map] missing
> Please run i.target for group map
> Not really sure what's going on here... tried it multiple ways. Any
> suggestions? Thanks!
> Joe
