[GRASS-user] I can't start grass after change the mapset
directory.
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Tue Aug 4 17:49:37 EDT 2009
Hi Nikos
I tryed this but not work:
$ /c/OSGeo4W/apps/grass/bin/grass64 -gui C:/Mymapset
Cleaning up temporary files ...
Starting GRASS ...
c:/Users/famiglia/C:/Mymapset: Not a valid GRASS location
^^^^^^^^^^^^^^^^^^^^ this part is not part of the mapset where I want to
work.
So I edited .grassrc6 and not I can access the desired mapset.
Thanks a lot.
milton
2009/8/4 Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>
> Milton Cezar Ribeiro:
> > I was working on a mapset stored on a external Hard Disk (like e:
> > \MyMapset).
> > This was my last access of mapset on grass.
> > Not I removed the external hard disk so I have no drive E anymore.
> > But when I start grass 6.4, it try to access the mapset on e:\MyMapset
> > and as it is not there, the grass stay stucked. What I need to do
> > to be able to choose my mapset?
> > By the way, I am running grass under MSYS/Vista.
> > cheers
> > milton
> Milton, no idea how grass can be launched under Windozes. Under linux
> you can just launch grass by specifying a location/mapset, e.g.:
> grass64 /grassdb/Location/Mapset
> That does (I think) away the problem with undetectable locations/mapsets
> (like in your case). Can't you just specify another location/mapset
> while launching grass from text/gui?
> Nikos
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090804/09db92fd/attachment-0001.html
