[GRASS-user] g.list not working on GUI after edit .grassrc6
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Tue Aug 4 18:55:04 EDT 2009
On Tue, 2009-08-04 at 18:30 -0400, Milton Cezar Ribeiro wrote:
> Dear all,
> I needed to edit .grassrc6 and set another
> mapset, because the "default" on .grassrc6
> was on an external hard disk, and I don't have
> it anymore.
> After edit .grassrc6 and set another Mapset
> I can startup grass without problem, but now
> when I try select one raster to be displayed,
> the list come empty. It happens with -gui option.
> But with -text I can run "g.list rast".
> The same occurs for another mapset that I copied
> from one machine to another.
> :: grass 6.4 / msys / vista.
> Any idea?
Perhaps a silly question: did you also set the location? Maybe the
mapset you have set up is not in the Location defined in .grassrc6?
Nikos
