[GRASS-user] g.list not working on GUI after edit .grassrc6
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Tue Aug 4 19:33:29 EDT 2009
Hi Nikos.
Thanks for the reply.
Yes, location is included on .grassrc6.
$ cat .grassrc6
GISDBASE: C:/Mymapset
LOCATION_NAME: newLocation
MAPSET: PERMANENT
GRASS_GUI: tcltk
Any other idea?!
cheers
milton
2009/8/4 Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de>
> On Tue, 2009-08-04 at 18:30 -0400, Milton Cezar Ribeiro wrote:
> > Dear all,
> > I needed to edit .grassrc6 and set another
> > mapset, because the "default" on .grassrc6
> > was on an external hard disk, and I don't have
> > it anymore.
> > After edit .grassrc6 and set another Mapset
> > I can startup grass without problem, but now
> > when I try select one raster to be displayed,
> > the list come empty. It happens with -gui option.
> > But with -text I can run "g.list rast".
> > The same occurs for another mapset that I copied
> > from one machine to another.
> > :: grass 6.4 / msys / vista.
> > Any idea?
> Perhaps a silly question: did you also set the location? Maybe the
> mapset you have set up is not in the Location defined in .grassrc6?
> Nikos
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090804/9b687a24/attachment.html
