[GRASS-user] g.list not working on GUI after edit .grassrc6
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Tue Aug 4 20:12:05 EDT 2009
On Tue, 2009-08-04 at 19:33 -0400, Milton Cezar Ribeiro wrote:
> Hi Nikos.
> Thanks for the reply.
> Yes, location is included on .grassrc6.
> $ cat .grassrc6
> GISDBASE: C:/Mymapset
> LOCATION_NAME: newLocation
> MAPSET: PERMANENT
> GRASS_GUI: tcltk
> Any other idea?!
> cheers
> milton
Milton,
from your previous post in the other thread it seems that you do not
define the location/mapset [1]. Did you try to start like:
"$ /c/OSGeo4W/apps/grass/bin/grass64 -gui
C:/Mymapset/newLocation/PERMANENT"
or
"$ /c/OSGeo4W/apps/grass/bin/grass64 -text
Anyhow, is there a directory newLocation under C:/Mymapset ?
And within the newLocation there must be the PERMANENT mapset (just
another directory).
Apologies that I insist, but I think (maybe I am wrong but double
checking never hurts) there might be some misunderstanding about
location/mapset. The first level directory is the so-called GRASS-DB.
Then you have within that location(s) and within the location(s) you
have mapset(s).
The way it appears in you other post [1] there is no location at all or
you name(d) the GRASS-DB as Mymapset? Maybe another naming-convention
could be better to avoid confusion with the GRASS-DB (which is just the
central directory containing all grass-stuff).
Sorry if I can't be of any help.
Nikos
[1] Copy-Paste from:
Re: [GRASS-user] g.list not working on GUI after edit .grassrc6
Date: Tue, 4 Aug 2009 19:33:29 -0400 (Wed, 01:33 CEST)
$ /c/OSGeo4W/apps/grass/bin/grass64 -gui C:/Mymapset Cleaning up
temporary files ...
Starting GRASS ...
c:/Users/famiglia/C:/Mymapset: Not a valid GRASS location
^^^^^^^^^^^^^^^^^^^^ this part is not part of the mapset where I want to
work.
