[GRASS-user] .ps map crashing with vlegend instructions
Casey Vandenberg casey.vandenberg at sjgeophysics.com
Wed Aug 5 13:33:20 EDT 2009
I have run across a seemingly random problem creating some maps with
.psmap instructions. If I run .psmap with vlegend included in the
instructions, it crashes and I get the error message included at the end
of the e-mail.  If I run the psmap isntructions with the vlegend
instructions turned off, or if I run the .psmap instructions with
vlegend turned on but with a different raster layer, it runs fine (no
changes have been made to the vector layers to display however).
Has anyone encountered this before or know of any workarounds? I can't
quite tell if the problem is caused by the raster file (hence why it
works with other raster maps) or if the problem is related to something
different.
Thanks,
Casey
Operand stack:
   1173.6
Execution stack:
   %interp_exit   .runexec2   --nostringval--   --nostringval--
--nostringval--   2   %stopped_push   --nostringval--
--nostringval--   --nostringval--   false   1   %stopped_push   1862
1   3   %oparray_pop   1861   1   3   %oparray_pop   1845   1   3
%oparray_pop   1739   1   3   %oparray_pop   --nostringval--
%errorexec_pop   .runexec2   --nostringval--   --nostringval--
Dictionary stack:
   --dict:1147/1684(ro)(G)--   --dict:0/20(G)--   --dict:146/200(L)--
Current allocation mode is local
Last OS error: 2
GPL Ghostscript 8.64: Unrecoverable error, exit code 1
Error: /limitcheck in -file-
Operand stack:
   1173.6
Execution stack:
Dictionary stack:
Last OS error: 2
