[GRASS-user] .ps map crashing with vlegend instructions
    Hamish
    hamish_b at yahoo.com
    Wed Aug  5 18:12:23 EDT 2009
Casey Vandenberg wrote:
> I have run across a seemingly random
> problem creating some maps with .psmap instructions. If I
> run .psmap with vlegend included in the instructions, it
> crashes and I get the error message included at the end of
> the e-mail.  If I run the psmap isntructions with the
> vlegend instructions turned off, or if I run the .psmap
> instructions with vlegend turned on but with a different
> raster layer, it runs fine (no changes have been made to the
> vector layers to display however).
> Has anyone encountered this before or know of any
> workarounds? I can't quite tell if the problem is caused by
> the raster file (hence why it works with other raster maps)
> or if the problem is related to something different.
can you reproduce it using the spearfish or NC sample datasets?
does it always fail with that certain set of instructions?
please post the ps.map instructions used, as simplified as
possible.
vlegend is being used for vector maps, right? :)
> Operand stack:
>   1173.6
> Execution stack:
> %interp_exit   .runexec2   --nostringval--   --nostringval--   --nostringval--   2   %stopped_push   --nostringval--   --nostringval--   --nostringval--   false   1   %stopped_push   1862   1   3   %oparray_pop   1861   1   3   %oparray_pop   1845   1   3   %oparray_pop   1739   1   3   %oparray_pop   --nostringval--   %errorexec_pop   .runexec2   --nostringval--   --nostringval--   --nostringval--   2   %stopped_push
> Dictionary stack:
> --dict:1147/1684(ro)(G)--   --dict:0/20(G)--   --dict:146/200(L)--
> Current allocation mode is local
> Last OS error: 2
> GPL Ghostscript 8.64: Unrecoverable error, exit code 1
> Error: /limitcheck in -file-
> Operand stack:
>   1173.6
> Execution stack:
> Dictionary stack:
> Last OS error: 2
is this Mac OSX? what version? what version of GRASS?
Hamish
