[GRASS-user] can I access mapset outside of grass,
by using python?
Glynn Clements
glynn at gclements.plus.com
Fri Aug 7 14:54:28 EDT 2009
Milton Cezar Ribeiro wrote:
> I can run some simple scripts on python if I start
> Msys -> grass64 -> python myscrypt.py
> But now I would like to know if I can build a python
> code outside of a msys/grass session, and get
> access on a mapset withour stay running grass.
The GRASS libraries require certain environment variables to be set. A
"GRASS session" is just a set of processes (e.g. a shell and/or GUI)
which have the necessary environment settings.
Specifically:
GISBASE needs to be set to the top-level directory of the GRASS
installation.
GISRC needs to contain the absolute path to a file containing settings
for GISDBASE, LOCATION_NAME and MAPSET.
PATH needs to include $GISBASE/bin and $GISBASE/scripts.
If the GRASS libraries are shared libraries, the loader needs to be
able to find them. This normally means that LD_LIBRARY_PATH (Linux,
Solaris), DYLD_LIBRARY_PATH (MacOSX) or PATH (Windows) need to contain
$GISBASE/lib, although there are other means to the same end (e.g. on
Linux, putting $GISBASE/lib (with $GISBASE replaced by its actual
value) into /etc/ld.so.conf then running ldconfig).
Some libraries and modules use other variables. See the file
$GISBASE/docs/html/variables.html for most of them (the display
libraries used by d.* commands use additional variables, which are
documented along with the individual drivers).
Personally, I have the following run from my ~/.bash_profile script:
export GISBASE=/usr/local/src/grass/svn/dist.i686-pc-linux-gnu
export GRASS_GNUPLOT='gnuplot -persist'
export GRASS_WIDTH=640
export GRASS_HEIGHT=480
export GRASS_HTML_BROWSER=firefox
export GRASS_PAGER=cat
export GRASS_WISH=wish
export GRASS_PYTHON=python
export GRASS_MESSAGE_FORMAT=silent
export GRASS_TRUECOLOR=TRUE
export GRASS_TRANSPARENT=TRUE
export GRASS_PNG_AUTO_WRITE=TRUE
export PATH="$GISBASE/bin:$GISBASE/scripts:$PATH"
export LD_LIBRARY_PATH="$GISBASE/lib"
export GRASS_LD_LIBRARY_PATH="$LD_LIBRARY_PATH"
export PYTHONPATH="$GISBASE/etc/python:$PYTHONPATH"
export MANPATH=$MANPATH:$GISBASE/man
export GIS_LOCK=$$
export GRASS_VERSION="7.0.svn"
tmp=/tmp/grass6-"`whoami`"-$GIS_LOCK
export GISRC="$tmp/gisrc"
mkdir "$tmp"
cp ~/.grassrc6 "$GISRC"
This allows GRASS commands to be used anywhere (my ~/.Xsession sources
the bash startup scripts, so the settings aren't limited to
interactive shells, but also work for e.g. M-! in XEmacs). Each
interactive shell gets a separate "session" (i.e. a separate $GISRC
file), while GUI programs share a common session.
The above is for GRASS 7, and uses the version from the dist.<arch>
directory in the GRASS source tree rather than an installed version.
The only time I ever start GRASS explicitly is if I need to test
changes to the startup scripts, or test a 6.x version.
