[GRASS-user] r.li help
Markus Neteler neteler at osgeo.org
Mon Aug 10 02:20:42 EDT 2009
On Mon, Aug 10, 2009 at 7:43 AM, Nathan Lemoine<lemoine.nathan at gmail.com> wrote:
> I just installed GRASS 6.4 on MacOS X and have been attempting to run some
> landscape analysis with the r.li modules. I can run the r.li.setup module
> just fine, but when I attempt to run r.li.patchnum or the density function
> it just crashes immediately. I've run it from the python GUI and the
> command-line and the same thing happens. Is there a fix for this?
Are you able to reproduce it with the Spearfish or North Carolina
data set? If yes, please tell us the steps and we try to reproduce
the problem. I ran a few r.li measures successfully recently on Linux (64bit).
Markus
