[GRASS-user] r.li help
    William Kyngesburye
    woklist at kyngchaos.com
    Mon Aug 10 09:38:48 EDT 2009
When it crashes, if you get a crash dialog box, click the Report
button and copy the details text from that (don't send the crash
report).
or
Run Console.app and look for a crash log for r.li.patchnum in your
home Library.
On Aug 10, 2009, at 12:43 AM, Nathan Lemoine wrote:
> I just installed GRASS 6.4 on MacOS X and have been attempting to
> run some landscape analysis with the r.li modules. I can run the
> r.li.setup module just fine, but when I attempt to run r.li.patchnum
> or the density function it just crashes immediately. I've run it
> from the python GUI and the command-line and the same thing happens.
> Is there a fix for this?
> Thanks,
> Nate
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"The beast is actively interested only in now, and, as it is always
now and always shall be, there is an eternity of time for the
accomplishment of objects."
- the wisdom of Tarzan
