[GRASS-user] r.li help
William Kyngesburye woklist at kyngchaos.com
Tue Aug 11 10:00:14 EDT 2009
Here's an interesting clue (or maybe a completely different problem) -
our previous crash was run 64bit.  When I force the 32bit binary to
run with arch -386 (OSX-only command) I still get lots of:
WARNING: Unable to open header file for raster map <@(null)>
CHILD[pid = xxxxx]: unable to open mask ... continue without!!!
but no illegal filename errors and no crash and all the workers
processes complete.  I don't know what the output is supposed to look
like, but the raster looks sensible.
I'll try poking around with some debugging.  Maybe a bug report is in
order also?
On Aug 11, 2009, at 12:28 AM, Markus Neteler wrote:
> On Mon, Aug 10, 2009 at 4:44 PM, Nathan Lemoine<lemoine.nathan at gmail.com
> > wrote:
>> I copied landuse96_28m file to the user1 MAPSET (I named the copy
>> "landuse"),
> (note that above step isn't really needed, but ok):
>> and used r.li.setup to make my config file. I named the config
>> file "mov" and selected the "landuse" raster file. I set the
>> sampling frame
>> to the whole region, and set the sampling area to a moving window.
>> I chose a
>> rectangular window of 5x5 cells. The config file was the set and
>> seemed to
>> be fine. I attempted to run r.li.patchnum rast=landuse config=mov
>> output=test and got the following reports:
>> This is the GRASS terminal report:
>> Illegal filename. Character < > not allowed.
> I have tried:
> GRASS 6.5.svn (nc_spm_08):~ > g.copy rast=landuse96_28m,landuse
> Copy raster <landuse96_28m at PERMANENT> to current mapset as <landuse>
> GRASS 6.5.svn (nc_spm_08):~ > g.region rast=landuse
> GRASS 6.5.svn (nc_spm_08):~ > r.li.patchnum landuse96_28m conf=mov
> output=test --o
> r.li.worker (pid 29902) terminated
> r.li.worker (pid 29909) terminated
> r.li.worker (pid 29910) terminated
> r.li.worker (pid 29905) terminated
> r.li.worker (pid 29903) terminated
> r.li.worker (pid 29908) terminated
> r.li.worker (pid 29906) terminated
> r.li.worker (pid 29907) terminated
> r.li.worker (pid 29904) terminated
> r.li.worker (pid 29911) terminated
> Also 6.4:
> GRASS 6.4.0svn (nc_spm_08):~ > r.li.patchnum landuse96_28m conf=mov
> output=test --o
> r.li.worker (pid 30035) terminated
> r.li.worker (pid 30034) terminated
> r.li.worker (pid 30029) terminated
> r.li.worker (pid 30030) terminated
> r.li.worker (pid 30033) terminated
> r.li.worker (pid 30037) terminated
> r.li.worker (pid 30038) terminated
> r.li.worker (pid 30032) terminated
> r.li.worker (pid 30036) terminated
> r.li.worker (pid 30031) terminated
> It works on Linux but apparently the map name gets lost in the r.li
> daemon
> on MacOSX.
> I am afraid that only debugging on Mac helps. The easiest is perhaps
> to add G_debug() statements if you don't want/cannot use  a gdb
> debugger -
> to figure out in which code area of r.li.daemon or r.li.patchnum the
> name
> disappears.
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
