[GRASS-user] r.li help
William Kyngesburye
woklist at kyngchaos.com
Tue Aug 11 11:56:43 EDT 2009
Markus - I ran patchdensity, here's the upper-left corner of the 32bit
run on the spearfish landuse raster, does this look the same as you
get? I'm wondering about the overlapping parts, if they should be
combined like that (it's working despite the mask errors) or if they
should be a single color/value or something else (it's not working)?
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20090811/f82e7e58/Picture1.png
On Aug 11, 2009, at 9:00 AM, William Kyngesburye wrote:
> Here's an interesting clue (or maybe a completely different problem)
> - our previous crash was run 64bit. When I force the 32bit binary
> to run with arch -386 (OSX-only command) I still get lots of:
> WARNING: Unable to open header file for raster map <@(null)>
> CHILD[pid = xxxxx]: unable to open mask ... continue without!!!
> but no illegal filename errors and no crash and all the workers
> processes complete. I don't know what the output is supposed to
> look like, but the raster looks sensible.
> I'll try poking around with some debugging. Maybe a bug report is
> in order also?
> On Aug 11, 2009, at 12:28 AM, Markus Neteler wrote:
>> On Mon, Aug 10, 2009 at 4:44 PM, Nathan Lemoine<lemoine.nathan at gmail.com
>> > wrote:
>>> I copied landuse96_28m file to the user1 MAPSET (I named the copy
>>> "landuse"),
>> (note that above step isn't really needed, but ok):
>>> and used r.li.setup to make my config file. I named the config
>>> file "mov" and selected the "landuse" raster file. I set the
>>> sampling frame
>>> to the whole region, and set the sampling area to a moving window.
>>> I chose a
>>> rectangular window of 5x5 cells. The config file was the set and
>>> seemed to
>>> be fine. I attempted to run r.li.patchnum rast=landuse config=mov
>>> output=test and got the following reports:
>>> This is the GRASS terminal report:
>>> Illegal filename. Character < > not allowed.
>> I have tried:
>> GRASS 6.5.svn (nc_spm_08):~ > g.copy rast=landuse96_28m,landuse
>> Copy raster <landuse96_28m at PERMANENT> to current mapset as <landuse>
>> GRASS 6.5.svn (nc_spm_08):~ > g.region rast=landuse
>> GRASS 6.5.svn (nc_spm_08):~ > r.li.patchnum landuse96_28m conf=mov
>> output=test --o
>> r.li.worker (pid 29902) terminated
>> r.li.worker (pid 29909) terminated
>> r.li.worker (pid 29910) terminated
>> r.li.worker (pid 29905) terminated
>> r.li.worker (pid 29903) terminated
>> r.li.worker (pid 29908) terminated
>> r.li.worker (pid 29906) terminated
>> r.li.worker (pid 29907) terminated
>> r.li.worker (pid 29904) terminated
>> r.li.worker (pid 29911) terminated
>> Also 6.4:
>> GRASS 6.4.0svn (nc_spm_08):~ > r.li.patchnum landuse96_28m conf=mov
>> output=test --o
>> r.li.worker (pid 30035) terminated
>> r.li.worker (pid 30034) terminated
>> r.li.worker (pid 30029) terminated
>> r.li.worker (pid 30030) terminated
>> r.li.worker (pid 30033) terminated
>> r.li.worker (pid 30037) terminated
>> r.li.worker (pid 30038) terminated
>> r.li.worker (pid 30032) terminated
>> r.li.worker (pid 30036) terminated
>> r.li.worker (pid 30031) terminated
>> It works on Linux but apparently the map name gets lost in the r.li
>> daemon
>> on MacOSX.
>> I am afraid that only debugging on Mac helps. The easiest is perhaps
>> to add G_debug() statements if you don't want/cannot use a gdb
>> debugger -
>> to figure out in which code area of r.li.daemon or r.li.patchnum
>> the name
>> disappears.
>> Markus
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those
> least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
