[GRASS-user] r.li help
William Kyngesburye woklist at kyngchaos.com
Wed Aug 12 10:58:06 EDT 2009
I did a little crude debugging yesterday (G_message) and found it
failed for me in daemon.c, line 626 / nextArea()
     else {
	return next(g, m);
But all this tells me is that at this point the mask name is missing,
not where it was lost.
I didn't have more time to poke around more.
Note: bug report at http://trac.osgeo.org/grass/ticket/718
On Aug 12, 2009, at 9:34 AM, Markus Neteler wrote:
> On Wed, Aug 12, 2009 at 3:38 PM, Paolo
> Cavallini<cavallini at faunalia.it> wrote:
>> Markus Neteler ha scritto:
>>> My result, upper left corner only, is attached (Mandriva Linux,
>>> 64bit).
>>> Visually it looks ok to me.
>> I'm also having problems with r.li:
>>> r.li.shannon map=uso conf=latignano_5 output=provaln
>> WARNING: Unable to open header file for raster map <@(null)>
>> CHILD[pid = 1954]: unable to open mask ... continue without!!!
>> CHILD[pid = 1953]: unable to open mask ... continue without!!!
>> CHILD[pid = 1952]: unable to open mask ... continue without!!!
>> CHILD[pid = 1951]: unable to open mask ... continue without!!!
>> CHILD[pid = 1950]: unable to open mask ... continue without!!!
>> CHILD[pid = 1949]: unable to open mask ... continue without!!!
>> CHILD[pid = 1948]: unable to open mask ... continue without!!!
>> CHILD[pid = 1947]: unable to open mask ... continue without!!!
>> CHILD[pid = 1946]: unable to open mask ... continue without!!!
>> CHILD[pid = 1945]: unable to open mask ... continue without!!!
>> Segmentation fault
>> Debian ustable, 64 bit.
>> Any hint appreciated.
> I see three options:
> - use the debugger
>  http://grass.osgeo.org/wiki/GRASS_Debugging#Using_GDB
> - otherwise fill the source code with G_debug() statements to figure
> out
>  where it fails (needs recompilation obviously)
> - grant access to a machine where it fails, hoping that a GRASS
>   developers tracks it down for you :)
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian]  What are you supposed to do WITH a maniacally depressed
robot?
[Marvin]  You think you have problems?  What are you supposed to do if
you ARE a maniacally depressed robot?  No, don't try and answer, I'm
50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
