[GRASS-user] r.li help
Nathan Lemoine
lemoine.nathan at gmail.com
Sun Aug 16 20:59:25 EDT 2009
I've tried running gdb on the r.li.patchnum program, but I have no
debugging or programming experience, so I can only report the error
messages I've received. running the program normally, without of gdb,
gets me the error:
Illegal filename. Character <> not allowed.
WARNING: Unable to open header file for raster map <@(null)>
CHILD[pid = 326]: unable to open mask ... continue without!!!
this error message typically just repeats itself.
running the program with gdb gets me:
Starting program: /Applications/GRASS-6.4.app/Contents/MacOS/bin/
r.li.patchnum .li.patchnum map=northrast conf=whole out=test
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: KERN_INVALID_ADDRESS at address: 0x0000000000000008
0x00007fff806b0964 in strcmp ()
and if I backtrace:
(gdb) bt
#0 0x00007fff806b0964 in strcmp ()
#1 0x000000010005bc63 in parseSetup ()
#2 0x000000010005c899 in calculateIndex ()
#3 0x00000001000008c8 in start ()
that's as much as I've been able to learn so far given my limited
skills at this.
On Aug 11, 2009, at 9:00 AM, William Kyngesburye wrote:
> Here's an interesting clue (or maybe a completely different problem)
> - our previous crash was run 64bit. When I force the 32bit binary
> to run with arch -386 (OSX-only command) I still get lots of:
> CHILD[pid = xxxxx]: unable to open mask ... continue without!!!
> but no illegal filename errors and no crash and all the workers
> processes complete. I don't know what the output is supposed to
> look like, but the raster looks sensible.
> I'll try poking around with some debugging. Maybe a bug report is
> in order also?
> On Aug 11, 2009, at 12:28 AM, Markus Neteler wrote:
>> On Mon, Aug 10, 2009 at 4:44 PM, Nathan Lemoine<lemoine.nathan at gmail.com
>> > wrote:
>>> I copied landuse96_28m file to the user1 MAPSET (I named the copy
>>> "landuse"),
>> (note that above step isn't really needed, but ok):
>>> and used r.li.setup to make my config file. I named the config
>>> file "mov" and selected the "landuse" raster file. I set the
>>> sampling frame
>>> to the whole region, and set the sampling area to a moving window.
>>> I chose a
>>> rectangular window of 5x5 cells. The config file was the set and
>>> seemed to
>>> be fine. I attempted to run r.li.patchnum rast=landuse config=mov
>>> output=test and got the following reports:
>>> This is the GRASS terminal report:
>>> Illegal filename. Character < > not allowed.
>> I have tried:
>> GRASS 6.5.svn (nc_spm_08):~ > g.copy rast=landuse96_28m,landuse
>> Copy raster <landuse96_28m at PERMANENT> to current mapset as <landuse>
>> GRASS 6.5.svn (nc_spm_08):~ > g.region rast=landuse
>> GRASS 6.5.svn (nc_spm_08):~ > r.li.patchnum landuse96_28m conf=mov
>> output=test --o
>> r.li.worker (pid 29902) terminated
>> r.li.worker (pid 29909) terminated
>> r.li.worker (pid 29910) terminated
>> r.li.worker (pid 29905) terminated
>> r.li.worker (pid 29903) terminated
>> r.li.worker (pid 29908) terminated
>> r.li.worker (pid 29906) terminated
>> r.li.worker (pid 29907) terminated
>> r.li.worker (pid 29904) terminated
>> r.li.worker (pid 29911) terminated
>> Also 6.4:
>> GRASS 6.4.0svn (nc_spm_08):~ > r.li.patchnum landuse96_28m conf=mov
>> output=test --o
>> r.li.worker (pid 30035) terminated
>> r.li.worker (pid 30034) terminated
>> r.li.worker (pid 30029) terminated
>> r.li.worker (pid 30030) terminated
>> r.li.worker (pid 30033) terminated
>> r.li.worker (pid 30037) terminated
>> r.li.worker (pid 30038) terminated
>> r.li.worker (pid 30032) terminated
>> r.li.worker (pid 30036) terminated
>> r.li.worker (pid 30031) terminated
>> It works on Linux but apparently the map name gets lost in the r.li
>> daemon
>> on MacOSX.
>> I am afraid that only debugging on Mac helps. The easiest is perhaps
>> to add G_debug() statements if you don't want/cannot use a gdb
>> debugger -
>> to figure out in which code area of r.li.daemon or r.li.patchnum
>> the name
>> disappears.
>> Markus
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those
> least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
