[GRASS-user] v.in.ogr to SDE
Fran Tarkington
fran.tarkington at gmail.com
Wed Aug 12 20:00:06 EDT 2009
Hi
I have grass installed using the osgeo4w. Am trying to use the v.in.ogr
command to import some vector data from an ESRI SDE data source.
I have successfully used the OGR2OGR utility that came installed with the
ogeo4w to extract vector data from SDE to a shapefile. When I open op a
osgoe4w command prompt and query the formats supported I get the following
list:
C:\Windows\system32>ogrinfo --formats
Supported Formats:
-> "OCI" (read/write)
-> "SDE" (readonly)
-> "ESRI Shapefile" (read/write)
-> "MapInfo File" (read/write)
-> "UK .NTF" (readonly)
-> "SDTS" (readonly)
-> "TIGER" (read/write)
-> "S57" (read/write)
-> "DGN" (read/write)
-> "VRT" (readonly)
-> "REC" (readonly)
-> "Memory" (read/write)
-> "BNA" (read/write)
-> "CSV" (read/write)
-> "GML" (read/write)
-> "GPX" (read/write)
-> "KML" (read/write)
-> "GeoJSON" (read/write)
-> "Interlis 1" (read/write)
-> "Interlis 2" (read/write)
-> "GMT" (read/write)
-> "SQLite" (read/write)
-> "ODBC" (read/write)
-> "PGeo" (readonly)
-> "OGDI" (readonly)
-> "PostgreSQL" (read/write)
-> "MySQL" (read/write)
-> "AVCBin" (readonly)
Yet when I try to use the v.in.ogr command with the following syntax I get
the error: Unable to open data source. The following is a summary of the
syntax that I am using:
v.in.ogr dsn=SDE:habs.ca,5153,ordb1,oraUserName,password,MYSCHEMA.LOCATIONS
output=LOCATIONS
Is there any way I can verify that the grass is using the same GDAL/OGR
versions as I am using on the OSGEO4W command line?
Any help would be appreciated.
Thanks
Fran
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090812/b1d42504/attachment.html
