[GRASS-user] v.edit break ERROR: Attempt to delete dead feature
achim
ak7 at jupiter.uni-freiburg.de
Thu Aug 13 11:40:43 EDT 2009
Hi all,
I try to break a couple of lines on specified points (nodes in a network
to get separated lines).
I do this with for one example-point successfully:
v.edit map=laflo_break at achim layer=1 type=line tool=break ids=0-9999999
thresh=-1,0.000001,0.000001 coords=32.6958333333333,8.67083333333333
but doing this with a list of more than 6 coors or having the same coor
twice in the list, I get the "Attempt to delete dead feature"-error.
Is there a limiting number of coords for v.edit or is it something else?
What does grass try when it "Attempt to delete dead feature"
Thanks,
Achim
PS: after error message the topology of vector-file is destroyed:
WARNING: Size of 'coor' file differs from value saved in topology file
WARNING: Please rebuild topology for vector map
