[GRASS-user] bus error in v.in.ogr
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Fri Aug 14 09:21:21 EDT 2009
Hi Maning,
O flyed on your email and saw only warnings, not errors.
It appears to worked.
bests
milton
2009/8/14 maning sambale <emmanuel.sambale at gmail.com>
> I am importing a polygon shapefile and I get this error. The
> shapefile was created using QGIS.
> v.in.ogr layer=forest_p116r048_repair output=forest_p116r048
> dsn=/Users/maning/pfua/map_data/forest_2002_digit/forest_p116r048_p117r047_edited
> --o
> WARNING: Vector map <forest_p116r048> already exists and will be
> overwritten
> Projection of input dataset and current location appear to match
> overwritten
> Layer: forest_p116r048_repair
> Importing map 181 features...
> WARNING: Area size [7.5e-09], area not imported
> Building topology for vector map <forest_p116r048>...
> 58952 vertices registered
> 230 primitives registered
> Building areas: 100%
> 225 areas built
> 225 isles built
> Attaching islands: 100%
> Attaching centroids: 100%
> Topology was built
> Number of nodes : 228
> Number of primitives: 230
> Number of points : 0
> Number of lines : 0
> Number of boundaries: 230
> Number of centroids : 0
> Number of areas : 225
> Number of isles : 225
> Number of incorrect boundaries : 5
> Number of areas without centroid : 225
> WARNING: Cleaning polygons, result is not guaranteed!
> Topology was built
> Number of lines : 0
> Number of areas : -
> Number of isles : -
> Break polygons:
> Registering points 46354
> All points (vertices): 58943
> Registered points (unique coordinates): 46354
> Points marked for break: 345
> Breaks: 610
> Remove duplicates:
> Duplicates: 230
> Break boundaries:
> Intersections: 39
> Remove duplicates:
> Duplicates: 7
> Clean boundaries at nodes:
> Modifications: 0Bus error
> cheers,
> maning
> "Freedom is still the most radical idea of all" -N.Branden
> wiki: http://esambale.wikispaces.com/
> blog: http://epsg4253.wordpress.com/
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090814/b19eb734/attachment.html
