[GRASS-user] bus error in v.in.ogr
maning sambale
emmanuel.sambale at gmail.com
Fri Aug 14 07:59:12 EDT 2009
I am importing a polygon shapefile and I get this error. The
shapefile was created using QGIS.
v.in.ogr layer=forest_p116r048_repair output=forest_p116r048
dsn=/Users/maning/pfua/map_data/forest_2002_digit/forest_p116r048_p117r047_edited
--o
WARNING: Vector map <forest_p116r048> already exists and will be
overwritten
Projection of input dataset and current location appear to match
overwritten
Layer: forest_p116r048_repair
Importing map 181 features...
WARNING: Area size [7.5e-09], area not imported
Building topology for vector map <forest_p116r048>...
58952 vertices registered
230 primitives registered
Building areas: 100%
225 areas built
225 isles built
Attaching islands: 100%
Attaching centroids: 100%
Topology was built
Number of nodes : 228
Number of primitives: 230
Number of points : 0
Number of lines : 0
Number of boundaries: 230
Number of centroids : 0
Number of areas : 225
Number of isles : 225
Number of incorrect boundaries : 5
Number of areas without centroid : 225
WARNING: Cleaning polygons, result is not guaranteed!
Topology was built
Number of lines : 0
Number of areas : -
Number of isles : -
Break polygons:
Registering points 46354
All points (vertices): 58943
Registered points (unique coordinates): 46354
Points marked for break: 345
Breaks: 610
Remove duplicates:
Duplicates: 230
Break boundaries:
Intersections: 39
Remove duplicates:
Duplicates: 7
Clean boundaries at nodes:
Modifications: 0Bus error
cheers,
maning
"Freedom is still the most radical idea of all" -N.Branden
wiki: http://esambale.wikispaces.com/
blog: http://epsg4253.wordpress.com/
