[GRASS-user] v.edit break ERROR: Attempt to delete dead feature
achim
ak7 at jupiter.uni-freiburg.de
Tue Aug 18 12:50:49 EDT 2009
in line 43 I updated a thresh:
v.edit --quiet map=$1 layer=1 type=line tool=break cats=$catlist
coords=$coord thresh=-1,0,0
-1,0,0 is default, but its to emphasize, that this is important!
Because it uses the current resolution as thresh, there will be done
something wrong with near points:
so resolution must be set up (grid size a third or whatever)
Achim
achim schrieb:
>> ## update network table with start,end point cats
>> ## takes a long time!!!
>> v.net -c --overwrite input=$1 operation=report > line_end_cats.txt
>> while read line; do
>> cat=$(echo $line | cut -d' ' -f1)
>> start=$(echo $line | cut -d' ' -f2)
>> end=$(echo $line | cut -d' ' -f3)
>> ## update network table, line layer
>> sqlite3 /home/achim/grass/sqlite_db "UPDATE $1
>> SET start=$start,end=$end WHERE cat = $cat;"
>> done < line_end_cats.txt
>> Can't you do this with v.to.db option=start / end ? Don't know if this
>> is faster, though...
> it would be faster, but v.to.db option=start/end just update the
> coordinate (x,y).
> then two double values instead of one integer will have to be compared
>> In any case, you can probably speed it up by putting all your SQL
>> statements into a file and then executing sqlite on that file outside
>> the loop. Database connections always create quite a lot of overhead.
> right, good idea. Another possibility would be to make a table from
> "v.net -c --overwrite input=$1 operation=report" and make the update
> with one sql statement. ...but its just a workaround and not a final
> version ;-).
> Achim
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- nächster Teil --------------
Ein Dateianhang mit Bin?rdaten wurde abgetrennt...
Dateiname : break_rivernetwork_correct.sh
Dateityp : application/x-shellscript
Dateigr??e : 1639 bytes
Beschreibung: nicht verf?gbar
URL : http://lists.osgeo.org/pipermail/grass-user/attachments/20090818/cd9a4f47/break_rivernetwork_correct.bin
