[GRASS-user] bus error in v.in.ogr
maning sambale
emmanuel.sambale at gmail.com
Fri Aug 14 09:40:08 EDT 2009
On Fri, Aug 14, 2009 at 9:39 PM, maning
sambale<emmanuel.sambale at gmail.com> wrote:
> There was a vector file but not layers so in effect, there was an error.
> On Fri, Aug 14, 2009 at 9:21 PM, Milton Cezar
> Ribeiro<miltinho.astronauta at gmail.com> wrote:
>> Hi Maning,
>> O flyed on your email and saw only warnings, not errors.
>> It appears to worked.
>> bests
>> milton
>> 2009/8/14 maning sambale <emmanuel.sambale at gmail.com>
>>> I am importing a polygon shapefile and I get this error. The
>>> shapefile was created using QGIS.
>>> v.in.ogr layer=forest_p116r048_repair output=forest_p116r048
>>> dsn=/Users/maning/pfua/map_data/forest_2002_digit/forest_p116r048_p117r047_edited
>>> --o
>>> WARNING: Vector map <forest_p116r048> already exists and will be
>>> overwritten
>>> Projection of input dataset and current location appear to match
>>> overwritten
>>> Layer: forest_p116r048_repair
>>> Importing map 181 features...
>>> WARNING: Area size [7.5e-09], area not imported
>>> Building topology for vector map <forest_p116r048>...
>>> 58952 vertices registered
>>> 230 primitives registered
>>> Building areas: 100%
>>> 225 areas built
>>> 225 isles built
>>> Attaching islands: 100%
>>> Attaching centroids: 100%
>>> Topology was built
>>> Number of nodes : 228
>>> Number of primitives: 230
>>> Number of points : 0
>>> Number of lines : 0
>>> Number of boundaries: 230
>>> Number of centroids : 0
>>> Number of areas : 225
>>> Number of isles : 225
>>> Number of incorrect boundaries : 5
>>> Number of areas without centroid : 225
>>> WARNING: Cleaning polygons, result is not guaranteed!
>>> Topology was built
>>> Number of lines : 0
>>> Number of areas : -
>>> Number of isles : -
>>> Break polygons:
>>> Registering points 46354
>>> All points (vertices): 58943
>>> Registered points (unique coordinates): 46354
>>> Points marked for break: 345
>>> Breaks: 610
>>> Remove duplicates:
>>> Duplicates: 230
>>> Break boundaries:
>>> Intersections: 39
>>> Remove duplicates:
>>> Duplicates: 7
>>> Clean boundaries at nodes:
>>> Modifications: 0Bus error
>>> cheers,
>>> maning
>>> "Freedom is still the most radical idea of all" -N.Branden
>>> wiki: http://esambale.wikispaces.com/
>>> blog: http://epsg4253.wordpress.com/
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
> cheers,
> maning
cheers,
maning
