[GRASS-user] bus error in v.in.ogr [SEC=PERSONAL]
Andrew MacIntyre Andrew.MacIntyre at acma.gov.au
Sun Aug 16 20:21:28 EDT 2009
A bus error is usually either an incorrectly aligned memory access or
an attempt to access a memory address not in the process' memory map.
I've mostly seen this when processes run out of stack space.
If the cleaning process uses recursive code, that could be a source of
a stack overflow.
You might check your session limits to see how much stack space is
permitted for each process.
-------------------------> "These thoughts are mine alone!" <---------
Andrew MacIntyre           National Licensing and Allocations Branch
tel:   +61 2 6219 5356     Inputs to Industry Division
fax:   +61 2 6253 3277     Australian Communications & Media Authority
email: andrew.macintyre at acma.gov.au            http://www.acma.gov.au/
If you have received this email in error, please notify the sender immediately and erase all copies of the email and any attachments to it. The information contained in this email and any attachments may be private, confidential and legally privileged or the subject of copyright. If you are not the addressee it may be illegal to review, disclose, use, forward, or distribute this email and/or its contents.
Unless otherwise specified, the information in the email and any attachments is intended as a guide only and should not be relied upon as legal or technical advice or regarded as a substitute for legal or technical advice in individual cases. Opinions contained in this email or any of its attachments do not necessarily reflect the opinions of ACMA.
