[GRASS-user] Running Scripts in GRASS
Markus Neteler
neteler at osgeo.org
Tue Aug 18 20:30:43 EDT 2009
On Wed, Aug 19, 2009 at 2:16 AM, Andrew Lewin<andrew.lewin at sympatico.ca> wrote:
> Thanks for the help, but I am not quite clear on the part you say the script
> has to be an executable.
(indeed, it is not a requirement, see below)
> I copied and pasted the script from the wiki page
> and stored it in ~/Library/GRASS/6.4/Modules/bin; called the script by
> typing it (called chlatransl) to the Terminal shell.
That's fine.
> It said "chlatranl not found".
.. because typically the current directory is not in the path.
If the executable flag is on (set with chmod or a file manager)
then run it like this:
a) in the directory where the script is with
./chlatransl
or
b) with full path from anywhere
/path/to/chlatransl
> How do I compile the script to
> make it an executable. Right now it is stored in a text file.
No need to compile (essentially, you cannot :)
If you want to even avoid the chmod/filemanager stuff, then
give it as parameter to "sh" which is the shell interpreter:
sh chlatransl
or
sh /path/to/chlatransl
Perhaps we should cook up a Wiki page describing this briefly?
Hope this helps,
Markus
