[GRASS-user] magic?
achim ak7 at jupiter.uni-freiburg.de
Thu Aug 20 11:49:44 EDT 2009
using a new location: no success
export and import as shape-file: no success
reproduce it with spearfish dataset: no success
Has anybody an idea?
I attach the problem-polygon as a shape... hope somebody has the same
problem with it ...and an idea.
Thanks,
Achim
achim schrieb:
> Hello,
> I used v.to.rast
>     v.to.rast --overwrite input=inmap output=outmap use=cat
> to convert 29 areas to raster.
> It says
>     Converted areas: 29 of 29
> but one area is missing!!!
> Its the one with cat number 16. Doing the same just for the selected 16,
> conversion results in am empty raster map.
> the same with use=attr or usr=val. Another vector map also does not
> convert some areas. The missing areas are not special
> What happens? Magic?
> I tried it with grass64 and newly compiled grass65. (OpenSuse 11.1 64bit)
> Achim
> PS:
> Layer: 1
> Typ       Anzahl        Min        Max
> Punkt          0          0          0
> Linie           0          0          0
> Grenze       0          0          0
> Zentroid      29          1         29
> Fläche           0          0          0
> Alle           29          1         29
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- nächster Teil --------------
Ein Dateianhang mit Bin?rdaten wurde abgetrennt...
Dateiname   : grass.zip
Dateityp    : application/zip
Dateigr??e  : 14501 bytes
Beschreibung: nicht verf?gbar
URL         : http://lists.osgeo.org/pipermail/grass-user/attachments/20090820/1c127c9b/grass-0001.zip
