[GRASS-user] magic?
achim ak7 at jupiter.uni-freiburg.de
Thu Aug 20 12:58:20 EDT 2009
I tried a lot. And I found a solution:
I made a buffer around the area with 0 distance. Then v.to.rast works.
If anyone knows why, it would be very interesting for me.
Moreover, when this happens in a big dataset, the error will probably
not recognized.
Thanks for attention,
Achim
achim schrieb:
> Hi,
> using a new location: no success
> export and import as shape-file: no success
> reproduce it with spearfish dataset: no success
> Has anybody an idea?
> I attach the problem-polygon as a shape... hope somebody has the same
> problem with it ...and an idea.
> Thanks,
> Achim
> achim schrieb:
>> Hello,
>> I used v.to.rast
>>     v.to.rast --overwrite input=inmap output=outmap use=cat
>> to convert 29 areas to raster.
>> It says
>>     Converted areas: 29 of 29
>> but one area is missing!!!
>> Its the one with cat number 16. Doing the same just for the selected 16,
>> conversion results in am empty raster map.
>> the same with use=attr or usr=val. Another vector map also does not
>> convert some areas. The missing areas are not special
>> What happens? Magic?
>> I tried it with grass64 and newly compiled grass65. (OpenSuse 11.1 64bit)
>> Achim
>> PS:
>> Layer: 1
>> Typ       Anzahl        Min        Max
>> Punkt          0          0          0
>> Linie           0          0          0
>> Grenze       0          0          0
>> Zentroid      29          1         29
>> Fläche           0          0          0
>> Alle           29          1         29
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
