[GRASS-user] magic?
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Thu Aug 20 13:47:58 EDT 2009
Hi Achim,
could you, please, share with us your region -p ?
bests
milton
2009/8/20 achim <ak7 at jupiter.uni-freiburg.de>
> Hi,
> I tried a lot. And I found a solution:
> I made a buffer around the area with 0 distance. Then v.to.rast works.
> If anyone knows why, it would be very interesting for me.
> Moreover, when this happens in a big dataset, the error will probably
> not recognized.
> Thanks for attention,
> Achim
> achim schrieb:
> > Hi,
> > using a new location: no success
> > export and import as shape-file: no success
> > reproduce it with spearfish dataset: no success
> > Has anybody an idea?
> > I attach the problem-polygon as a shape... hope somebody has the same
> > problem with it ...and an idea.
> > Thanks,
> > Achim
> > achim schrieb:
> >> Hello,
> >> I used v.to.rast
> >> v.to.rast --overwrite input=inmap output=outmap use=cat
> >> to convert 29 areas to raster.
> >> It says
> >> Converted areas: 29 of 29
> >> but one area is missing!!!
> >> Its the one with cat number 16. Doing the same just for the selected 16,
> >> conversion results in am empty raster map.
> >> the same with use=attr or usr=val. Another vector map also does not
> >> convert some areas. The missing areas are not special
> >> What happens? Magic?
> >> I tried it with grass64 and newly compiled grass65. (OpenSuse 11.1
> 64bit)
> >> Achim
> >> PS:
> >> Layer: 1
> >> Typ Anzahl Min Max
> >> Punkt 0 0 0
> >> Linie 0 0 0
> >> Grenze 0 0 0
> >> Zentroid 29 1 29
> >> Fläche 0 0 0
> >> Alle 29 1 29
> >> _______________________________________________
> >> grass-user mailing list
> >> grass-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090820/a460a343/attachment-0001.html
