[GRASS-user] Reading list of vector maps into file or array
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Thu Aug 20 12:10:04 EDT 2009
Hi Mark,
Have you tried something like grass.mlist_grouped(type = 'rast') (may be you
need change to "vect") on python?
good luck
milton
2009/8/20 M S <mseibel at gmail.com>
> Greetings All:
> How would one read the vector maps in a current mapset into a file, or a
> list in an array (using python)? If I do 'g.list vect > walker.list', the
> list is not in one column and seems to be separated by tabs, with 4 columns
> and a bunch of rows of vector files. Would a simple solution be to begin
> processing that redirected output?
> As background...
> After running the r.sim.water module, I get a bunch of walkerXXXX vector
> maps as outputs for given intervals. Works well thus far.
> I'm building an animated GIF of the walkers over time, on a shaded DEM.
> The method I am using is tedious and am seeking to automate the process. I
> load all the layers (shaded DEM, walkers at various intervals) and turn on
> one walker vector, and output a .png from the display monitor. Wash, rinse,
> repeat until all walkers have been captured as an image, then animate them
> with the 'convert' command.
> If anyone has some suggestions on how to get vector maps into a list,
> please let me know. Also, if there is a better way to solve this problem,
> any feedback would be greatly appreciated.
> Mark
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090820/7ce961c1/attachment.html
