[GRASS-user] wxpython Mac OS X compilation issues
William Kyngesburye woklist at kyngchaos.com
Fri Aug 21 09:58:39 EDT 2009
wxpython should work fine with the system python.  I don't remember
how the installer works to do this, I think it's automatic.
Do you have:
/Library/Python/2.5/site-packages/wx.pth
After starting GRASS, run Python within the GRASS shell.  What do you
get from:
import sys
sys.path
On Aug 21, 2009, at 8:39 AM, stephen sefick wrote:
> I first used the system python and then I installed the latest
> wxPython.  Should, I go through and only use the system python, make
> use of the newest python, or...?  Thanks for the help.
> Stephen Sefick
> On Fri, Aug 21, 2009 at 8:33 AM, William
> Kyngesburye<woklist at kyngchaos.com> wrote:
>> On Aug 20, 2009, at 11:36 PM, stephen sefick wrote:
>>> from with in GRASS
>>> g.gui wxpython
>>> ERROR: wxGUI requires wxPython >= 2.8.1.1.
>>> dlopen(/System/Library/Frameworks/Python.framework/Versions/2.5/
>>> Extras/lib/python/wx-2.8-mac-unicode/wx/_core_.so,
>>> 2): Symbol not found: __ZN15wxPoint2DDouble14SetVectorAngleEe
>>>  Referenced from:
>>> /System/Library/Frameworks/Python.framework/Versions/2.5/Extras/
>>>  Expected in:
>>> /Applications/GRASS-6.4.app/Contents/MacOS/lib/
>>> libwx_macud-2.8.0.dylib
>>> . Detailed information in README file.
>>> Any help tracking this down would be gratefully appreciated.
>> For some reason, GRASS is not using your wxpython.  Maybe it's not
>> in your
>> sys.path.
>> Did you install the python.org Python or are you using the system
>> python?
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> "This is a question about the past, is it? ... How can I tell that
>> the past
>> isn't a fiction designed to account for the discrepancy between my
>> immediate
>> physical sensations and my state of mind?"
>> - The Ruler of the Universe
> Stephen Sefick
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods.  We are mammals, and have not exhausted the
> annoying little problems of being mammals.
> 								-K. Mullis
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
