[GRASS-user] wxpython Mac OS X compilation issues
stephen sefick
ssefick at gmail.com
Fri Aug 21 09:39:45 EDT 2009
I first used the system python and then I installed the latest
wxPython. Should, I go through and only use the system python, make
use of the newest python, or...? Thanks for the help.
Stephen Sefick
On Fri, Aug 21, 2009 at 8:33 AM, William
Kyngesburye<woklist at kyngchaos.com> wrote:
> On Aug 20, 2009, at 11:36 PM, stephen sefick wrote:
>> from with in GRASS
>> g.gui wxpython
>> ERROR: wxGUI requires wxPython >= 2.8.1.1.
>> dlopen(/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python/wx-2.8-mac-unicode/wx/_core_.so,
>> 2): Symbol not found: __ZN15wxPoint2DDouble14SetVectorAngleEe
>> Referenced from:
>> Expected in:
>> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libwx_macud-2.8.0.dylib
>> . Detailed information in README file.
>> Any help tracking this down would be gratefully appreciated.
> For some reason, GRASS is not using your wxpython. Maybe it's not in your
> sys.path.
> Did you install the python.org Python or are you using the system python?
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that the past
> isn't a fiction designed to account for the discrepancy between my immediate
> physical sensations and my state of mind?"
> - The Ruler of the Universe
Stephen Sefick
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods. We are mammals, and have not exhausted the
annoying little problems of being mammals.
-K. Mullis
