[GRASS-user] wxpython Mac OS X compilation issues
William Kyngesburye woklist at kyngchaos.com
Fri Aug 21 18:26:28 EDT 2009
... it's been a while since using the wxpython installer, I currently
use a custom-compiled wxpython so I can embed it in GRASS... and it
looks like that should be:
wxredirect.pth
It should be installed automatically by the wxpython installer.
On Aug 21, 2009, at 5:11 PM, stephen sefick wrote:
> I do not have
> /Library/Python/2.5/site-packages/wx.pth
> how do I get it?
> On Fri, Aug 21, 2009 at 8:58 AM, William
> Kyngesburye<woklist at kyngchaos.com> wrote:
>> wxpython should work fine with the system python.  I don't remember
>> how the
>> installer works to do this, I think it's automatic.
>> Do you have:
>> After starting GRASS, run Python within the GRASS shell.  What do
>> you get
>> from:
>> import sys
>> sys.path
>> On Aug 21, 2009, at 8:39 AM, stephen sefick wrote:
>>> I first used the system python and then I installed the latest
>>> wxPython.  Should, I go through and only use the system python, make
>>> use of the newest python, or...?  Thanks for the help.
>>> Stephen Sefick
>>> On Fri, Aug 21, 2009 at 8:33 AM, William
>>>> On Aug 20, 2009, at 11:36 PM, stephen sefick wrote:
>>>>> from with in GRASS
>>>>> g.gui wxpython
>>>>> ERROR: wxGUI requires wxPython >= 2.8.1.1.
>>>>> dlopen(/System/Library/Frameworks/Python.framework/Versions/2.5/
>>>>> Extras/lib/python/wx-2.8-mac-unicode/wx/_core_.so,
>>>>> 2): Symbol not found: __ZN15wxPoint2DDouble14SetVectorAngleEe
>>>>>  Referenced from:
>>>>> /System/Library/Frameworks/Python.framework/Versions/2.5/Extras/
>>>>>  Expected in:
>>>>> /Applications/GRASS-6.4.app/Contents/MacOS/lib/
>>>>> libwx_macud-2.8.0.dylib
>>>>> . Detailed information in README file.
>>>>> Any help tracking this down would be gratefully appreciated.
>>>> For some reason, GRASS is not using your wxpython.  Maybe it's
>>>> not in
>>>> your
>>>> sys.path.
>>>> Did you install the python.org Python or are you using the system
>>>> python?
>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>> http://www.kyngchaos.com/
>>>> "This is a question about the past, is it? ... How can I tell
>>>> that the
>>>> past
>>>> isn't a fiction designed to account for the discrepancy between my
>>>> immediate
>>>> physical sensations and my state of mind?"
>>>> - The Ruler of the Universe
>>> Stephen Sefick
>>> Let's not spend our time and resources thinking about things that
>>> are
>>> so little or so large that all they really do for us is puff us up
>>> and
>>> make us feel like gods.  We are mammals, and have not exhausted the
>>> annoying little problems of being mammals.
>>>        -K.
>>> Mullis
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> "History is an illusion caused by the passage of time, and time is an
>> illusion caused by the passage of history."
>> - Hitchhiker's Guide to the Galaxy
> Stephen Sefick
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> 								-K. Mullis
"Mon Dieu! but they are all alike.  Cheating, murdering, lying,
fighting, and all for things that the beasts of the jungle would not
deign to possess - money to purchase the effeminate pleasures of
weaklings.  And yet withal bound down by silly customs that make them
slaves to their unhappy lot while firm in the belief that they be the
lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
