[GRASS-user] wxpython Mac OS X compilation issues
stephen sefick
ssefick at gmail.com
Fri Aug 21 18:29:34 EDT 2009
wxredirect.pth is there.
On Fri, Aug 21, 2009 at 5:26 PM, William
Kyngesburye<woklist at kyngchaos.com> wrote:
> ... it's been a while since using the wxpython installer, I currently use a
> custom-compiled wxpython so I can embed it in GRASS... and it looks like
> that should be:
> wxredirect.pth
> It should be installed automatically by the wxpython installer.
> On Aug 21, 2009, at 5:11 PM, stephen sefick wrote:
>> I do not have
>> /Library/Python/2.5/site-packages/wx.pth
>> how do I get it?
>> On Fri, Aug 21, 2009 at 8:58 AM, William
>>> wxpython should work fine with the system python. I don't remember how
>>> the
>>> installer works to do this, I think it's automatic.
>>> Do you have:
>>> After starting GRASS, run Python within the GRASS shell. What do you get
>>> from:
>>> import sys
>>> sys.path
>>> On Aug 21, 2009, at 8:39 AM, stephen sefick wrote:
>>>> I first used the system python and then I installed the latest
>>>> wxPython. Should, I go through and only use the system python, make
>>>> use of the newest python, or...? Thanks for the help.
>>>> Stephen Sefick
>>>> On Fri, Aug 21, 2009 at 8:33 AM, William
>>>>> On Aug 20, 2009, at 11:36 PM, stephen sefick wrote:
>>>>>> from with in GRASS
>>>>>> g.gui wxpython
>>>>>> ERROR: wxGUI requires wxPython >= 2.8.1.1.
>>>>>> dlopen(/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python/wx-2.8-mac-unicode/wx/_core_.so,
>>>>>> 2): Symbol not found: __ZN15wxPoint2DDouble14SetVectorAngleEe
>>>>>> Referenced from:
>>>>>> Expected in:
>>>>>> /Applications/GRASS-6.4.app/Contents/MacOS/lib/libwx_macud-2.8.0.dylib
>>>>>> . Detailed information in README file.
>>>>>> Any help tracking this down would be gratefully appreciated.
>>>>> For some reason, GRASS is not using your wxpython. Maybe it's not in
>>>>> your
>>>>> sys.path.
>>>>> Did you install the python.org Python or are you using the system
>>>>> python?
>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>> http://www.kyngchaos.com/
>>>>> "This is a question about the past, is it? ... How can I tell that the
>>>>> past
>>>>> isn't a fiction designed to account for the discrepancy between my
>>>>> immediate
>>>>> physical sensations and my state of mind?"
>>>>> - The Ruler of the Universe
>>>> Stephen Sefick
>>>> Let's not spend our time and resources thinking about things that are
>>>> so little or so large that all they really do for us is puff us up and
>>>> make us feel like gods. We are mammals, and have not exhausted the
>>>> annoying little problems of being mammals.
>>>> -K. Mullis
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>> "History is an illusion caused by the passage of time, and time is an
>>> illusion caused by the passage of history."
>>> - Hitchhiker's Guide to the Galaxy
>> Stephen Sefick
>> -K. Mullis
> "Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting,
> and all for things that the beasts of the jungle would not deign to possess
> - money to purchase the effeminate pleasures of weaklings. And yet withal
> bound down by silly customs that make them slaves to their unhappy lot while
> firm in the belief that they be the lords of creation enjoying the only real
> pleasures of existence....
> - the wisdom of Tarzan
Stephen Sefick
-K. Mullis
