[GRASS-user] wxpython Mac OS X compilation issues
    William Kyngesburye
    woklist at kyngchaos.com
    Fri Aug 21 20:37:43 EDT 2009
So, what about this, within the GRASS shell:
python
import sys
sys.path
On Aug 21, 2009, at 5:29 PM, stephen sefick wrote:
> wxredirect.pth is there.
> On Fri, Aug 21, 2009 at 5:26 PM, William
> Kyngesburye<woklist at kyngchaos.com> wrote:
>> ... it's been a while since using the wxpython installer, I
>> currently use a
>> custom-compiled wxpython so I can embed it in GRASS... and it looks
>> like
>> that should be:
>> wxredirect.pth
>> It should be installed automatically by the wxpython installer.
>> On Aug 21, 2009, at 5:11 PM, stephen sefick wrote:
>>> I do not have
>>> /Library/Python/2.5/site-packages/wx.pth
>>> how do I get it?
>>> On Fri, Aug 21, 2009 at 8:58 AM, William
>>>> wxpython should work fine with the system python.  I don't
>>>> remember how
>>>> the
>>>> installer works to do this, I think it's automatic.
>>>> Do you have:
>>>> After starting GRASS, run Python within the GRASS shell.  What do
>>>> you get
>>>> from:
>>>> import sys
>>>> sys.path
>>>> On Aug 21, 2009, at 8:39 AM, stephen sefick wrote:
>>>>> I first used the system python and then I installed the latest
>>>>> wxPython.  Should, I go through and only use the system python,
>>>>> make
>>>>> use of the newest python, or...?  Thanks for the help.
>>>>> Stephen Sefick
>>>>> On Fri, Aug 21, 2009 at 8:33 AM, William
>>>>>> On Aug 20, 2009, at 11:36 PM, stephen sefick wrote:
>>>>>>> from with in GRASS
>>>>>>> g.gui wxpython
>>>>>>> ERROR: wxGUI requires wxPython >= 2.8.1.1.
>>>>>>> dlopen(/System/Library/Frameworks/Python.framework/Versions/
>>>>>>> 2.5/Extras/lib/python/wx-2.8-mac-unicode/wx/_core_.so,
>>>>>>> 2): Symbol not found: __ZN15wxPoint2DDouble14SetVectorAngleEe
>>>>>>>  Referenced from:
>>>>>>> /System/Library/Frameworks/Python.framework/Versions/2.5/
>>>>>>>  Expected in:
>>>>>>> /Applications/GRASS-6.4.app/Contents/MacOS/lib/
>>>>>>> libwx_macud-2.8.0.dylib
>>>>>>> . Detailed information in README file.
>>>>>>> Any help tracking this down would be gratefully appreciated.
>>>>>> For some reason, GRASS is not using your wxpython.  Maybe it's
>>>>>> not in
>>>>>> your
>>>>>> sys.path.
>>>>>> Did you install the python.org Python or are you using the system
>>>>>> python?
>>>>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>>>>> http://www.kyngchaos.com/
>>>>>> "This is a question about the past, is it? ... How can I tell
>>>>>> that the
>>>>>> past
>>>>>> isn't a fiction designed to account for the discrepancy between
>>>>>> my
>>>>>> immediate
>>>>>> physical sensations and my state of mind?"
>>>>>> - The Ruler of the Universe
>>>>> Stephen Sefick
>>>>> Let's not spend our time and resources thinking about things
>>>>> that are
>>>>> so little or so large that all they really do for us is puff us
>>>>> up and
>>>>> make us feel like gods.  We are mammals, and have not exhausted
>>>>> the
>>>>> annoying little problems of being mammals.
>>>>> K. Mullis
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> grass-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>> "History is an illusion caused by the passage of time, and time
>>>> is an
>>>> illusion caused by the passage of history."
>>>> - Hitchhiker's Guide to the Galaxy
>>> Stephen Sefick
>>> Let's not spend our time and resources thinking about things that
>>> are
>>> so little or so large that all they really do for us is puff us up
>>> and
>>> make us feel like gods.  We are mammals, and have not exhausted the
>>>        -K.
>>> Mullis
>> "Mon Dieu! but they are all alike.  Cheating, murdering, lying,
>> fighting,
>> and all for things that the beasts of the jungle would not deign to
>> possess
>> - money to purchase the effeminate pleasures of weaklings.  And yet
>> withal
>> bound down by silly customs that make them slaves to their unhappy
>> lot while
>> firm in the belief that they be the lords of creation enjoying the
>> only real
>> pleasures of existence....
>> - the wisdom of Tarzan
> Stephen Sefick
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> 								-K. Mullis
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
