[GRASS-user] wxpython Mac OS X compilation issues
William Kyngesburye
woklist at kyngchaos.com
Sun Aug 23 23:31:03 EDT 2009
That looks right, so I don't know why the system wxpython is loaded.
I wonder, have you installed my GRASS binaries in the past? The
current 6.4rc5 includes a bundled wxpython. If you then compile your
own GRASS 6.4, it installs over mine, but leaves the bundled wxpython
except without a key setting to use it properly. This may then really
confuse GRASS when trying to start the GUI. Try deleting GRASS and
reinstalling your compiled version.
On Aug 23, 2009, at 1:28 PM, stephen sefick wrote:
> here is what I get from running the following command from within a
> GRASS shell:
> python
> import sys
> sys.path
> ['', '/Library/Frameworks/SQLite3.framework/Versions/3/Python',
> '/Library/Frameworks/GEOS.framework/Versions/3/Python/geos',
> '/Library/Frameworks/GDAL.framework/Versions/1.6/Python/site-
> packages',
> '/Applications/GRASS-6.4.app/Contents/MacOS/etc/python',
> '/usr/local/lib/wxPython-unicode-2.8.10.1/lib/python2.5/site-
> packages',
> packages/wx-2.8-mac-unicode',
> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/
> python25.zip',
> python2.5',
> python2.5/plat-darwin',
> python2.5/plat-mac',
> python2.5/plat-mac/lib-scriptpackages',
> '/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/
> python',
> python2.5/lib-tk',
> python2.5/lib-dynload',
> '/Library/Python/2.5/site-packages',
> '/usr/local/lib/wxPython-unicode-2.8.10.1/lib/python2.5',
> python/PyObjC']
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between
my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
