[GRASS-user] wxpython Mac OS X compilation issues
    stephen sefick
    ssefick at gmail.com
    Mon Aug 24 20:49:16 EDT 2009
I have used your binary, and I will try this when I get back to the
house in a couple of days.
thanks,
Stephen
On Sun, Aug 23, 2009 at 10:31 PM, William
Kyngesburye<woklist at kyngchaos.com> wrote:
> That looks right, so I don't know why the system wxpython is loaded.
> I wonder, have you installed my GRASS binaries in the past?  The current
> 6.4rc5 includes a bundled wxpython.  If you then compile your own GRASS 6.4,
> it installs over mine, but leaves the bundled wxpython except without a key
> setting to use it properly.  This may then really confuse GRASS when trying
> to start the GUI.  Try deleting GRASS and reinstalling your compiled
> version.
> On Aug 23, 2009, at 1:28 PM, stephen sefick wrote:
>> here is what I get from  running the following command from within a
>> GRASS shell:
>> python
>> import sys
>> sys.path
>> ['', '/Library/Frameworks/SQLite3.framework/Versions/3/Python',
>> '/Library/Frameworks/GEOS.framework/Versions/3/Python/geos',
>> '/Library/Frameworks/GDAL.framework/Versions/1.6/Python/site-packages',
>> '/Applications/GRASS-6.4.app/Contents/MacOS/etc/python',
>> '/usr/local/lib/wxPython-unicode-2.8.10.1/lib/python2.5/site-packages',
>> '/usr/local/lib/wxPython-unicode-2.8.10.1/lib/python2.5/site-packages/wx-2.8-mac-unicode',
>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python25.zip',
>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5',
>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-darwin',
>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-mac',
>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/plat-mac/lib-scriptpackages',
>> '/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python',
>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-tk',
>> '/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/lib-dynload',
>> '/Library/Python/2.5/site-packages',
>> '/usr/local/lib/wxPython-unicode-2.8.10.1/lib/python2.5',
>> '/System/Library/Frameworks/Python.framework/Versions/2.5/Extras/lib/python/PyObjC']
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that the past
> isn't a fiction designed to account for the discrepancy between my immediate
> physical sensations and my state of mind?"
> - The Ruler of the Universe
Stephen Sefick
Let's not spend our time and resources thinking about things that are
so little or so large that all they really do for us is puff us up and
make us feel like gods.  We are mammals, and have not exhausted the
annoying little problems of being mammals.
								-K. Mullis
