[GRASS-user] Problem running v.rast.stats - caused by
calculating coefficient of variance when mean=0?
Tim Holland
timothyholland at gmail.com
Wed Aug 26 23:51:14 EDT 2009
Thanks Hamish. You were right about the CV returning 'nan' on zeros, and in
the end it did seem that was not the problem.
The issue eventually seemed to be that the column prefixes I was using were
too long. When I went down to using 2- and 3-letter prefixes, it seemed to
start working fine (initially I had been using 5- or 6-letter prefixes). I
probably should have thought of that earlier, but...
In any case, working well now, so thanks for the help.
Best,
Tim
hamish-2 wrote:
> Tim wrote:
>> I am trying to use v.rast.stats in GRASS 6.4, but cannot get it to
>> work with the vector file I am using. Vector data I am using is
>> administrative boundaries (provinces of Vietnam) with the raster
>> being forest cover data at 500m x 500m pixel size.
>> Interestingly, it works fine when I use certain subsets of
>> my vector file (various sets of provinces selected at random), just not
>> when I use the whole file (i.e. all provinces). When I use the
>> complete provinces file, it finishes with errors (copied below).
>> When I check the attribute table, it has created the 9 columns it
>> is supposed to, but they are all blank.
>> Updating the database ...
>> ERROR: This should not happen: wrong return type in
>> parsing.
>> dbmi: Protocol error
>> ERROR: Error while executing: 'UPDATE NorthEast_NoIslands
>> SET TrChng_cf_=inf WHERE cat=3'
>> Because of the error message ("TrChng_cf_=inf WHERE cat=3",
>> I think the issue may have to do with calculating the coefficient
>> of variation when the mean of an area is equal to zero.
>> The precision of this data is not particularly high, and pixels
>> with value zero are common, so with many small islands, the likelihood
>> of a couple of them having a mean of zero is quite high.
>> If v.rast.stats (which performs its calculations by calling r.univar,
>> I believe)
> yes
>> is unable to calculate the coefficient of variation in one category
>> because of a mean of zero, does that cause the rest of the run to be
>> unsuccessful? Is that what is happening here?
> #test
> r.mapcalc zero=0
> r.univar zero
> sets cf_var to nan for me.
> If I try to update a DBF table with a nan or inf into to a double column:
> v.db.addcol local_bugs col='cfv double'
> echo "UPDATE local_bugs SET cfv=nan" | db.execute
> echo "UPDATE local_bugs SET cfv=inf" | db.execute
> both those work for me as far as I can tell (v.db.select shows those
> columns as empty)
>> If so, is there any way around this? I am not even interested in the
>> coefficient of variation, as I am only looking for very basic stats
>> (n, mean, max, min). Is there any way to tell it to skip the CV, or
>> is there another work-around anyone can think of?
> to test your theory: find and edit the v.rast.stats script,
> find this line:
> BASECOLS="n min max range mean stddev variance cf_var sum"
> and remove cf_var from it.
>> Or is this some other problem entirely?
> could be... but the "inf" is definitely an obvious suspect.
> also you might try changing to the SQLite driver instead of the less
> flexible DBF one. (see db.connect help page)
> Hamish
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/Problem-running-v-rast-stats-caused-by-calculating-coefficient-of-variance-when-mean-0-tp3502369p3521188.html
Sent from the Grass - Users mailing list archive at Nabble.com.
