[GRASS-user] Hortonian analysis - current status
Jarek Jasiewicz
jarekj at amu.edu.pl
Thu Aug 27 07:46:53 EDT 2009
Dear grass users!
I present next version of tools for hortonian analysis. Source code and
tutorial are available here:
http://heretic.livenet.pl/heretic/
Currently following modules are available:
- r.stream.order: to calculate Strahler, Horton, Shreve and main stream
(Hack) ordering. That module is almost ready to use
- r.stream.basins: calculate basins according users input. Read more on
web page
- r.stream.distance: calculate downslope distance path and elevation
above to streams/outlets. That module is in early development stage, but
works, and results seems good. But it may will change in the feature.
-r.streams.stats: calculate hortonian statistics is not avilable: maybe
in next few days.
All three modules works fine on small dems (up to 20 millions cells).
Only on powerful machines with at least 2-4GB RAM they handle avarage
dems (up to 120 M cells). I have no information about largers dems (over
100M cells because I haven't so).
Till I finish my work modules are available only from my web page. After
I will absolutely sure that everything is OK, add vector capabilities
and solve problems with massive dems (for LIDAR puropse) I will try to
add them to GRASS add-ons.
best regards
Jarek Jasiewicz
