[GRASS-user] MAP Calculator mean of eight neighbors to interpolate 0 value in raster map
stephen sefick ssefick at gmail.com
Fri Aug 28 13:37:53 EDT 2009
This does not quite work for my purposes.  The problem is the the 0
values are in a 2 or 3 grid wide seam in between patched raster maps,
so the value is lower than it should be using
r.mapcalc "benning_dem=if(patch_benning==0,
(patch_benning[-1,-1]+patch_benning[1,-1]+patch_benning[-1,0]+
patch_benning[1,0]+patch_benning[-1,1]+patch_benning[1,1])/6,
patch_benning)"
any thoughts,
Stephen Sefick
On Fri, Aug 28, 2009 at 12:08 PM, Milton Cezar
Ribeiro<miltinho.astronauta at gmail.com> wrote:
> Hi stephen,
> just to remember not include yourmap[0,0]
> bests
> milton
> 2009/8/28 stephen sefick <ssefick at gmail.com>
>> I think so- let me try it
>> On Fri, Aug 28, 2009 at 12:04 PM, achim<ak7 at jupiter.uni-freiburg.de>
>> wrote:
>> > r.mapcalc "newmap = if ( yourmap==0 , ( sum( yourmap[-1,1] ,
>> > yourmap[0,1] , ...)/8 ) , yourmap)"
>> > is that what you mean?
>> > stephen sefick schrieb:
>> >> if(0, (sum([-1,1], [0, 1], [1,1], [-1,0], [0,0], [1,0],[-1,-1],
>> >> [0,-1],[1,-1])/8))
>> >> I want to use mapcalc to do the above.  I am missing a syntax step.
>> >> if a value is zero take the average of the eight nearest neighbors and
>> >> replace the value with this.  Otherwise, keep the value unchanged
>> Stephen Sefick
>> Let's not spend our time and resources thinking about things that are
>> so little or so large that all they really do for us is puff us up and
>> make us feel like gods.  We are mammals, and have not exhausted the
>> annoying little problems of being mammals.
>>        -K. Mullis
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Stephen Sefick
								-K. Mullis
