[GRASS-user] MAP Calculator mean of eight neighbors to
interpolate 0 value in raster map
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Fri Aug 28 13:48:13 EDT 2009
Hi Stephen, may be you can share some picture?
bests
milton
2009/8/28 stephen sefick <ssefick at gmail.com>
> This does not quite work for my purposes. The problem is the the 0
> values are in a 2 or 3 grid wide seam in between patched raster maps,
> so the value is lower than it should be using
> r.mapcalc "benning_dem=if(patch_benning==0,
> (patch_benning[-1,-1]+patch_benning[1,-1]+patch_benning[-1,0]+
> patch_benning[1,0]+patch_benning[-1,1]+patch_benning[1,1])/6,
> patch_benning)"
> any thoughts,
> Stephen Sefick
> On Fri, Aug 28, 2009 at 12:08 PM, Milton Cezar
> Ribeiro<miltinho.astronauta at gmail.com> wrote:
> > Hi stephen,
> > just to remember not include yourmap[0,0]
> > bests
> > milton
> >> I think so- let me try it
> >> On Fri, Aug 28, 2009 at 12:04 PM, achim<ak7 at jupiter.uni-freiburg.de>
> >> wrote:
> >> > r.mapcalc "newmap = if ( yourmap==0 , ( sum( yourmap[-1,1] ,
> >> > yourmap[0,1] , ...)/8 ) , yourmap)"
> >> > is that what you mean?
> >> > stephen sefick schrieb:
> >> >> if(0, (sum([-1,1], [0, 1], [1,1], [-1,0], [0,0], [1,0],[-1,-1],
> >> >> [0,-1],[1,-1])/8))
> >> >> I want to use mapcalc to do the above. I am missing a syntax step.
> >> >> if a value is zero take the average of the eight nearest neighbors
> and
> >> >> replace the value with this. Otherwise, keep the value unchanged
> >> Stephen Sefick
> >> Let's not spend our time and resources thinking about things that are
> >> so little or so large that all they really do for us is puff us up and
> >> make us feel like gods. We are mammals, and have not exhausted the
> >> annoying little problems of being mammals.
> >> -K.
> Mullis
> >> _______________________________________________
> >> grass-user mailing list
> >> grass-user at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-user
> Stephen Sefick
> -K. Mullis
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090828/727057eb/attachment-0001.html
