[GRASS-user] reproject from lat/long to utm
maning sambale
emmanuel.sambale at gmail.com
Wed Dec 2 01:50:51 EST 2009
try this:
r.proj input=dem dbase=/work/projects/ location=Willamette mapset=PERMANENT
On Wed, Dec 2, 2009 at 2:45 PM, maning sambale
<emmanuel.sambale at gmail.com> wrote:
> On Wed, Dec 2, 2009 at 2:28 PM, Janet Choate <jsc.eco at gmail.com> wrote:
>> I tried using the full path (i.e. the PERMANENT mapset lives within the
>> /work/projects/Willamette location), but get the 'not found' error.
>> is there any other command i need to run prior to r.proj, or any additional
>> options to include, or how to list the path other than the way i am?
> just to check from your lat/long mapset, run g.gisenv
> It should show you the location, mapset and GRASS database.
> This is what you use in r.proj parameters
>> the original data i imported was a dem from usgs national elevation dataset
>> (ned) seamless data distribution system (sdds). i had to export it from ned
>> as a geotiff to bring it into grass. i tried exporting the data from ned as
>> an arcgrid and importing into grass with r.in.gdal, but was unable to bring
>> it into grass.
>> so if anyone can tell me the steps to bringing ned seamless data into grass,
>> then reprojecting to utm, i would be grateful. or at this point, just how
>> to use r.proj to reproject to utm.
>> thanx, janet
>> On Tue, Dec 1, 2009 at 10:14 PM, maning sambale <emmanuel.sambale at gmail.com>
>> wrote:
>>> Try to include the full path of your location
>>> ([/work/projects/Willamette])
>>> On Wed, Dec 2, 2009 at 1:47 PM, Janet Choate <jsc.eco at gmail.com> wrote:
>>> > HI,
>>> > thanx for any help. seems this should be a pretty straight forward
>>> > thing to
>>> > do, but am not having any success.
>>> > i am trying to reproject a raster from lat/long to utm.
>>> > i created a new location with a utm projection, then tried to use r.proj
>>> > to
>>> > reproject a raster from another location.
>>> > r.proj input=dem location=/work/projects/Willamette mapset=PERMANENT
>>> > however, i get the following error:
>>> > Mapset [PERMANENT] in input location [/work/projects/Willamette] - not
>>> > found
>>> > thanx for any assistance,
>>> > Janet
>>> > _______________________________________________
>>> > grass-user mailing list
>>> > grass-user at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/grass-user
>>> cheers,
>>> maning
>>> "Freedom is still the most radical idea of all" -N.Branden
>>> wiki: http://esambale.wikispaces.com/
>>> blog: http://epsg4253.wordpress.com/
> cheers,
> maning
cheers,
maning
