[GRASS-user] reproject from lat/long to utm
Janet Choate jsc.eco at gmail.com
Wed Dec 2 07:38:27 EST 2009
ok, getting somewhere!
however, now i'm getting the error 'Input map is outside current region',
which must be due to how i set up the new location.  when i set up the new
location/mapset, for 'define new location with...'
i chose 'Projection values'
then gave a new location name=GRASSnew, mapset=PERMANENT,
database=/work/projects
then specified the coordinate system for the new location as UTM,
datum nad83, datum tranformation Parameters chose option 6, zone 10, then on
the define the default region page - left the default region as it was with
N and E edge at 1, W and S edge at 0, and leaving Grid Resolution at 1,
accepted this region, successfully created location and reentered grass.
then ran r.proj as you suggested, and appeared to be correct input, but got
the input map is outside current region error.
any ideas?
thanx for all you help!
On Tue, Dec 1, 2009 at 10:50 PM, maning sambale
<emmanuel.sambale at gmail.com>wrote:
> try this:
> r.proj input=dem dbase=/work/projects/ location=Willamette mapset=PERMANENT
> On Wed, Dec 2, 2009 at 2:45 PM, maning sambale
> <emmanuel.sambale at gmail.com> wrote:
> > On Wed, Dec 2, 2009 at 2:28 PM, Janet Choate <jsc.eco at gmail.com> wrote:
> >> I tried using the full path (i.e. the PERMANENT mapset lives within the
> >> /work/projects/Willamette location), but get the 'not found' error.
> >> is there any other command i need to run prior to r.proj, or any
> additional
> >> options to include, or how to list the path other than the way i am?
> > just to check from your lat/long mapset, run g.gisenv
> > It should show you the location, mapset and GRASS database.
> > This is what you use in r.proj parameters
> >> the original data i imported was a dem from usgs national elevation
> dataset
> >> (ned) seamless data distribution system (sdds).  i had to export it from
> ned
> >> as a geotiff to bring it into grass.  i tried exporting the data from
> ned as
> >> an arcgrid and importing into grass with r.in.gdal, but was unable to
> bring
> >> it into grass.
> >> so if anyone can tell me the steps to bringing ned seamless data into
> grass,
> >> then reprojecting to utm, i would be grateful.  or at this point, just
> how
> >> to use r.proj to reproject to utm.
> >> thanx, janet
> >> On Tue, Dec 1, 2009 at 10:14 PM, maning sambale <
> >> wrote:
> >>> Try to include the full path of your location
> >>> ([/work/projects/Willamette])
> >>> On Wed, Dec 2, 2009 at 1:47 PM, Janet Choate <jsc.eco at gmail.com>
> wrote:
> >>> > HI,
> >>> > thanx for any help.  seems this should be a pretty straight forward
> >>> > thing to
> >>> > do, but am not having any success.
> >>> > i am trying to reproject a raster from lat/long to utm.
> >>> > i created a new location with a utm projection, then tried to use
> r.proj
> >>> > to
> >>> > reproject a raster from another location.
> >>> > r.proj input=dem location=/work/projects/Willamette mapset=PERMANENT
> >>> > however, i get the following error:
> >>> > Mapset [PERMANENT] in input location [/work/projects/Willamette] -
> not
> >>> > found
> >>> > thanx for any assistance,
> >>> > Janet
> >>> > _______________________________________________
> >>> > grass-user mailing list
> >>> > grass-user at lists.osgeo.org
> >>> > http://lists.osgeo.org/mailman/listinfo/grass-user
> >>> cheers,
> >>> maning
> >>> "Freedom is still the most radical idea of all" -N.Branden
> >>> wiki: http://esambale.wikispaces.com/
> >>> blog: http://epsg4253.wordpress.com/
> > cheers,
> > maning
> cheers,
> maning
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091202/63d63dd0/attachment-0001.html
