[GRASS-user] Re: grass-user Digest, Vol 44, Issue 14
Michael Barton
michael.barton at asu.edu
Thu Dec 3 13:08:21 EST 2009
On Dec 3, 2009, at 10:04 AM, grass-user-request at lists.osgeo.org wrote:
> Date: Thu, 3 Dec 2009 17:51:59 +0100
> From: Alfredo Alessandrini <alfreale74 at gmail.com>
> Subject: [GRASS-user] set region from display
> To: grass-user at lists.osgeo.org
> Message-ID:
> <d2c05c5a0912030851g1bdf0ec1u66613d19b7cf3223 at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> Hi,
> There is a shell command for set "computational region from display"?
> Thanks,
> Alfredo
There is not. But this is a potentially useful script to be used
within the display environment. However, in order to create the
display you want to do it this way, you will need to use a mouse (drag
a magnification up or down box). So it is not much effort to then pick
the relevant menu item off the display.
A possibly more useful command line script would be to set the display
to match the computational region.
You can always set the computational region from the command line
using g.region of course.
Michael
