[GRASS-user] Problem with grib support for GRASS 6.4
Markus Neteler
markus.neteler at iasma.it
Fri Dec 4 17:13:10 EST 2009
Thomas Adams wrote:
> All:
> I have (re-)compiled GRASS 6.4 to try and ensure that I am getting
> grib support in gdal within GRASS. When I attempt to import a grib
> file using r.in.gdal, I get an error and GRASS tells me that the file
> format is not recognized and is not supported. When I list the
> supported file formats for r.in.gdal, I can not find grib listed as a
> supported file format. OK, this seems to make sense, except that I did
> link to gdal (which I built from source) and if I run: gdalinfo
> gribfilename.grb, I get very reasonable output about the file. So, I
> don't understand why gdalinfo recognizes my grib file, yet GRASS
> linked against gdal does not list grib as a supported file format and
> does not recognizes my grib file.
Tom,
please check with
ldd `which r.in.gdal`
ldd `which gdalinfo`
which GDAL libs are used. Perhap you have two installations on the machine?
Markus
