[GRASS-user] grass70 and display monitor
Martin Landa
landa.martin at gmail.com
Sun Dec 6 04:00:42 EST 2009
2009/12/5 Jan Hartmann <j.l.h.hartmann at uva.nl>:
>> A point on digitizing. If you haven't tried it, you should take a look at
>> the digitizing that Martin has built into the new GUI. Because it has
>> hot-key equivalents for all buttons, you CAN digitize with your right hand
>> on the mouse and left on the keyboard. It also has a lot of contextual menus
>> that you access by right clicking while you digitize rather than having to
>> move to a separate text area like in 5.4.
> Ah, I hadn't realized that. Is that in GRASS 7? I don't use GRASS enough
no, it waits to be implemented (generally speaking easy task), see [1].
Martin
[1] http://trac.osgeo.org/grass/ticket/497
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
