[GRASS-user] Re: Problems displaying d.vect.thematic
Omar Bautista González omarbautistag at gmail.com
Wed Dec 9 19:30:09 EST 2009
Here, I report more information:
> v.info JCE_M2006
 | Layer:           JCE_M2006                                                 |
 | Mapset:          user1                                                     |
 | Location:        MapeosElectorales                                         |
 | Database:        /home/omar/grassdata                                      |
 | Title:        |
 | Map scale:       1:1                                                       |
 | Map format:      native                                                    |
 | Name of creator:                                                           |
 | Organization:                                                              |
 | Source date:                                                               |
 |   Type of Map:  vector (level: 2)                                          |
 |   Number of points:       0               Number of areas:      9909       |
 |   Number of lines:        0               Number of islands:    8          |
 |   Number of boundaries:   20227           Number of faces:      0          |
 |   Number of centroids:    5078            Number of kernels:    0          |
 |   Map is 3D:              No                                               |
 |   Number of dblinks:      1                                                |
 |         Projection: Unknown projection                                     |
 |               N:    2204990.860491    S:  1941029.08979587                 |
 |               E:   571289.72171435    W:   182391.61052347                 |
 |   Digitization threshold: 0                                                |
 |   Comments:        |
> db.describe table=JCE_M2006 driver=db
table:JCE_M2006
description:
insert:yes
delete:yes
ncols:31
nrows:151
column:CAT
description:
type:INTEGER
len:19
scale:0
precision:18
default:
nullok:yes
select:yes
update:yes
column:COD_JCE_M
description:
type:CHARACTER
len:3
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:CODIGO
description:
type:CHARACTER
len:8
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:COD_JCE_P
description:
type:CHARACTER
len:2
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:PROVINCIA
description:
type:CHARACTER
len:22
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:MUNICIPIO
description:
type:CHARACTER
len:26
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:A_GANADORA
description:
type:CHARACTER
len:5
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:ALIANZATRI
description:
type:CHARACTER
len:8
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:ALIANZAMAX
description:
type:DOUBLE PRECISION
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:R_ALIANZAM
description:
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:RD_ALIANZA
description:
len:4
scale:2
precision:2
default:
nullok:yes
select:yes
update:yes
column:ALIANZAMIN
description:
type:CHARACTER
len:9
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:ALIANZAMI2
description:
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:R_ALIANZA2
description:
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:PARTIDOMAX
description:
type:CHARACTER
len:8
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:PARTIDOMA2
description:
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:R_PARTIDOM
description:
len:4
scale:2
precision:2
default:
nullok:yes
select:yes
update:yes
column:RD_PARTIDO
description:
len:4
scale:2
precision:2
default:
nullok:yes
select:yes
update:yes
column:MINOR_AMAX
description:
type:CHARACTER
len:9
scale:0
precision:0
default:
nullok:yes
select:yes
update:yes
column:MINORIAMAX
description:
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:R_MINORIAM
description:
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:C_VOTOS
description:
len:19
scale:6
precision:17
default:
nullok:yes
select:yes
update:yes
column:P_VOTOS
description:
len:19
scale:6
precision:17
default:
nullok:yes
select:yes
update:yes
column:T_INSCRITO
description:
len:19
scale:6
precision:17
default:
nullok:yes
select:yes
update:yes
column:V_EMITIDOS
description:
len:19
scale:6
precision:17
default:
nullok:yes
select:yes
update:yes
column:P_VOTANTES
description:
len:19
scale:6
precision:17
default:
nullok:yes
select:yes
update:yes
column:C_ABSTENCI
description:
len:19
scale:6
precision:17
default:
nullok:yes
select:yes
update:yes
column:P_ABSTENCI
description:
len:19
scale:6
precision:17
default:
nullok:yes
select:yes
update:yes
column:ESPACIAL_C
description:
len:5
scale:2
precision:3
default:
nullok:yes
select:yes
update:yes
column:ESPACIAL_A
description:
len:4
scale:2
precision:2
default:
nullok:yes
select:yes
update:yes
column:ESPACIAL_P
description:
len:4
scale:2
precision:2
default:
nullok:yes
select:yes
update:yes
Regards,
2009/12/9 Omar Bautista González <omarbautistag at gmail.com>:
> I tested, the same command on an older version of GRASS and it worked
> (6.2.3). So I think this is a bug on this recent version (6.4.0RC5).
> I also tried simpler commands with d.vect.thematic and didn't worked
> with 6.4.0RC5. These commands worked well on 6.2.3.
> ¿What can we do to solve this module? I'm not programming on C now. If
> I would I'll try to figure out some changes on d.vect.thematic module.
> Att.
> 2009/12/7 Omar Bautista González <omarbautistag at gmail.com>:
>> Hello:
>> The problem is with the d.vect.thematic command. It don't display
>> nothing on the monitor. Even when other commands do it right.
>> I did the following commands:
>>> d.mon x0
>>> d.vect.thematic -s map=JCE_M2006 type=area column=RD_ALIANZA  layer=1 icon=basic/circle size=5  maxsize=20 nint=4 pointcolor=255:0:0  linecolor=0:0:0 startcolor=255:0:0 endcolor=0:0:255  themetype=graduated_colors monitor=none  themecalc=interval colorscheme=blue-red;
>> And nothing is displayed. Here are the output errors:
>> Segmentation fault
>> Thematic map legend for column RD_ALIANZA of map JCE_M2006
>> Value range: -
>> Mapped by 4 intervals of -inf
>> Color(R:G:B)    Value
>> 0:0:255          -
>> DBMI-DBF driver error:
>> SQL parser error: syntax error, unexpected AND processing 'and'
>> in statement:
>> SELECT cat FROM JCE_M2006 WHERE RD_ALIANZA >=  and RD_ALIANZA<=
>> Error in db_open_select_cursor()
>> 85:0:170                 -
>> in statement:
>> SELECT cat FROM JCE_M2006 WHERE RD_ALIANZA >  and RD_ALIANZA<=
>> 170:0:85                 -
>> in statement:
>> 255:0:0          -
>> in statement:
>> I installed ubuntu 6.10 on a Dell Mini 10. Then from the repositories
>> I installed GRASS 6.4.0RC5.
>> This is very strange because other commands are displaying well. Like
>> the following:
>> d.vect.chart map=PuntosCentralesM2006
>> type=point,line,boundary,centroid  layer=1
>> columns=C_PLD,C_PRD,C_PRSC,C_OTROS  ctype=pie ocolor=black
>> sizecol=P_OTROS size=15 scale=1 colors=purple,white,red,yellow;
>> I tried also with the GUI having the same problem.
>> Regards,
>> - Coordinador de Investigación para el Desarrollo,
>> Diseño, Monitoreo y Evaluación
>> Visión Mundial República Dominicana
