[GRASS-user] r.stream.basins
Jarek Jasiewicz
jarekj at amu.edu.pl
Fri Dec 11 13:59:42 EST 2009
Francesco Mirabella pisze:
> Hi all,
> I trying to compile the r.stream.basins module from the add-ons. I
> have checkout on the the latest svn version but I get some errors
> (below), can someone give help?
> many thanks
> Francesco
> cd /usr/local/svn/grass/grass-addons/raster/r.stream.basins
> francesco at terra17:/usr/local/svn/grass/grass-addons/raster/r.stream.basins$
> make MODULE_TOPDIR=/usr/local/svn/grass/grass640_rc5/
> gcc -L/usr/local/svn/grass/grass640_rc5/dist.i686-pc-linux-gnu/lib
> -Wl,--export-dynamic
> -Wl,-rpath-link,/usr/local/svn/grass/grass640_rc5/dist.i686-pc-linux-gnu/lib
> -o
> /usr/local/svn/grass/grass640_rc5/dist.i686-pc-linux-gnu/bin/r.stream.basins
> OBJ.i686-pc-linux-gnu/catchment.o OBJ.i686-pc-linux-gnu/io.o
> OBJ.i686-pc-linux-gnu/main.o -lgrass_gis -lgrass_datetime -lz
> -lm -lz
> OBJ.i686-pc-linux-gnu/catchment.o: In function `find_outlets':
> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/catchment.c:29:
> undefined reference to `G_malloc'
> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/catchment.c:37:
> undefined reference to `G_realloc'
> OBJ.i686-pc-linux-gnu/io.o: In function `create_maps':
> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/io.c:41:
> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/io.c:42:
> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/io.c:45:
> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/io.c:46:
> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/io.c:54:
> OBJ.i686-pc-linux-gnu/io.o:/usr/local/svn/grass/grass-addons/raster/r.stream.basins/io.c:55:
> more undefined references to `G_malloc' follow
> OBJ.i686-pc-linux-gnu/main.o: In function `main':
> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/main.c:41:
> undefined reference to `G_gisinit'
> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/main.c:116:
> collect2: ld returned 1 exit status
> make: ***
> [/usr/local/svn/grass/grass640_rc5/dist.i686-pc-linux-gnu/bin/r.stream.basins]
> Error 1
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
It looks like r.stream.basins do not see grass library headers. As I see
you have GRASS compiled from source, you can simply copy r.stream.basins
to you source/raster directory and make again.
BTW: r.stream.basins is prepared to work with grass65 because in
cooperation in r.stream.extract and r.stream.order it can use multiple
flow direction which is only implemented in r.watershed from grass65. So
I strongly recommend you update grass to the newest svn version
regards
J.
