[GRASS-user] r.stream.basins
Francesco Mirabella
mirabell at unipg.it
Thu Dec 17 05:55:20 EST 2009
Hi Jarek,
thanks for your message, I already have installed the r.stream.extract
and r.stream.order in grass64rc5.
I have tried copying the r.stream.basins directory directly into the
source raster directory but I get the same error. Also, I updated the
latest svn version of both grass64rc5 and grass70 but in grass64rc5 I
still get the same error, while in grass70 I can't "make libs" (see
below) prior to "make".
francesco at terra17:/usr/local/svn/grass/grass_trunk$ make libs
make -C lib/ headers
make[1]: Entering directory `/usr/local/svn/grass/grass_trunk/lib'
Makefile:66: warning: overriding commands for target
`/usr/local/svn/grass/grass_trunk/dist.i686-pc-linux-gnu/include/grass'
../include/Make/Rules.make:16: warning: ignoring old commands for target
make[1]: *** No rule to make target `headers'. Stop.
make[1]: Leaving directory `/usr/local/svn/grass/grass_trunk/lib'
make: *** [libs] Error 2
Do you think I should try grass65 ?
Francesco
Jarek Jasiewicz wrote:
> Francesco Mirabella pisze:
>> Hi all,
>> I trying to compile the r.stream.basins module from the add-ons. I
>> have checkout on the the latest svn version but I get some errors
>> (below), can someone give help?
>> many thanks
>> Francesco
>> cd /usr/local/svn/grass/grass-addons/raster/r.stream.basins
>> francesco at terra17:/usr/local/svn/grass/grass-addons/raster/r.stream.basins$
>> make MODULE_TOPDIR=/usr/local/svn/grass/grass640_rc5/
>> gcc -L/usr/local/svn/grass/grass640_rc5/dist.i686-pc-linux-gnu/lib
>> -Wl,--export-dynamic
>> -Wl,-rpath-link,/usr/local/svn/grass/grass640_rc5/dist.i686-pc-linux-gnu/lib
>> -o
>> /usr/local/svn/grass/grass640_rc5/dist.i686-pc-linux-gnu/bin/r.stream.basins
>> OBJ.i686-pc-linux-gnu/catchment.o OBJ.i686-pc-linux-gnu/io.o
>> OBJ.i686-pc-linux-gnu/main.o -lgrass_gis -lgrass_datetime -lz
>> -lm -lz
>> OBJ.i686-pc-linux-gnu/catchment.o: In function `find_outlets':
>> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/catchment.c:29:
>> undefined reference to `G_malloc'
>> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/catchment.c:37:
>> undefined reference to `G_realloc'
>> OBJ.i686-pc-linux-gnu/io.o: In function `create_maps':
>> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/io.c:41:
>> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/io.c:42:
>> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/io.c:45:
>> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/io.c:46:
>> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/io.c:54:
>> OBJ.i686-pc-linux-gnu/io.o:/usr/local/svn/grass/grass-addons/raster/r.stream.basins/io.c:55:
>> more undefined references to `G_malloc' follow
>> OBJ.i686-pc-linux-gnu/main.o: In function `main':
>> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/main.c:41:
>> undefined reference to `G_gisinit'
>> /usr/local/svn/grass/grass-addons/raster/r.stream.basins/main.c:116:
>> collect2: ld returned 1 exit status
>> make: ***
>> [/usr/local/svn/grass/grass640_rc5/dist.i686-pc-linux-gnu/bin/r.stream.basins]
>> Error 1
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> It looks like r.stream.basins do not see grass library headers. As I see
> you have GRASS compiled from source, you can simply copy r.stream.basins
> to you source/raster directory and make again.
> BTW: r.stream.basins is prepared to work with grass65 because in
> cooperation in r.stream.extract and r.stream.order it can use multiple
> flow direction which is only implemented in r.watershed from grass65. So
> I strongly recommend you update grass to the newest svn version
> regards
> J.
